I serviced industrial motors for 40 years .
Single phase motors have capacitors. Easy test is replace cap with new cap see if motor runs. Cap can be same size or larger but not smaller. Dirty or bad motor contacts inside the motor can cause problems too.
Start up current is always several times tag rating LRA for about 1/2 of a second.
Check the motor starter. Heaters on motor starters go bad. Example sometimes motor starter will trip with 10% or 20% less current than rated. Sometimes motor starters go bad too.
