fezder
I hope audioguru doesn't spill nuts when I yet again ask of this IC....
So, I made 30 leds version, last led is for 100w/4ohms (not peak value though) and leds are laddered 3db apart.
Following circuit does what I'm looking for, and can be modifed for either slow-decay or as in normal on/off fashion what lm3915 does. First of these behaviours I'm more after. So that is why I can't, or can't find suitable way to use your peak detector circuit that you supplied earlier audioguru.
Idea behind this circuit I came up on is simpe; comparator changes that small change in led on/off for proper pulse, this then controls pulse strecther, that is finally fed to opamp (lm358 works well in this application....). Due the amount of parts needed for only one led, you can see why I ask this, maybe there is better way? Please no microcontrollers, or double-supply, I can buy quite pile of components with price of another PSU...
I left those 2 other stages of lm3915's out from circuit as they aren't issue.
Any ideas/questions?
![slow-decay-circuit.jpg slow-decay-circuit.jpg](https://www.electro-tech-online.com/data/attachments/88/88435-770ebe087d95c61cf461f4870cf86b33.jpg)
There is possible issue of oscillation with comparator, and I could omit last opamp, but then I'd need bigger capacitor to keep led live and that in turn could lead bigger inrush current of capacitors...
