Aight so im new here... I have an idea for my car....
I have a switch panel that i custom made for my car... I want it to be able to flip out when i switch the car on, and to go back to the position it once was when i turn off the car.
The people here, most, like you to fill in your location. Some places in the world do not have Radio Shack (some wish they did not), so location helps.
Also when you want to know a price this is an issue.
I would drop the hip talk, most people here do not deal with posts like that unless they see your location is somwhere where that is not your first language.
So, you have a panel and you want it to flip down 90 degrees when your ignition goes hot. When you turn the key off you want it to go vertical again? Does it have a latch or lock on it?
Aight i'll do the location thing..my bad.. i just made the account a little while ago, so i haven't done anythin wit it.... so yea, u got the idea, basically flip down 90 degrees when the car is on, and when i turn it off, to go to its original position, no at the moment, there is no latch or lock on it
nobody here will help a wise cracking cool dude that can't even be bothered to use proper written english, or as close thereto, when they come here to ask for help with something...it confuses matters no end when english is not your first language.
You could do it with a changeover relay, a small hydraulic pump with reservoir, a couple of shut off valves and a small ram with ball end fittings and a couple of pivot points.
Or
a changeover relay, a long stroke solenoid capable of pulling as well as pushing with suitable pivot points and mechanics and a couple of limit switches.
Or
if you arrange the pivot point for the flap so that it is not at the bottom but rather is offset a little, you could fashion some sort of lever and toothed belt drive using a stepper motor, control electronics and a couple of limit switches.
Personally I would prefer the first solution, because it's easier, but both the first suggestion and the last one will allow you to regulate the speed at which the flap moves quite easily. The solenoid idea will require to have a damper fitted to control it's speed.
