Sitting around the hanger and discussing the possibility of somehow using
off-the-shelf electronic/computer components or gadgits for semi-automatic wing leveling on lightly loaded, short wingspans.
Not being computer guys, the current thought is that something should be out there that is available cheaply and modifiable to use a simple wing
leveler.
Having heard someplace that automotive computers, as an example, sense data millions of times leads us to believe that sensing the wing tip initial movement and counteracting very very quickly would be a good thing.
As an example: One fellow pictured a rolling ball bearing inside a tube
somehow activating a magnetic switch which in turn pulses a dc linear motor to operate the aileron minutely. Consensus was this was old tsch and impractical.
We are not sure how to detect the very earliest initial wing tip movement or drive the small trim type motor and would appreciate some thoughts or site recommendations to investigate.
Jst old guys needing smarter people's help <G>.
Thanks, Dick64
leveler.
Thanks, Dick64
