Alert Alarm System
butters
hi all... im currently doing on this project(attached).. basically my part is the communication between microcontroller and remote system and acknowledgement (slides 7 and 8)... basically i have tried various examples but i couldnt find a way to do it.. pointers and helps are much appreciated...
#include <p18f4520.h>
#include <usart.h>
#include <delays.h>
#include <portb.h>
unsigned char c;
unsigned char c1;
unsigned char c2;
unsigned char c3;
unsigned char c4;
unsigned char c5;
  unsigned char c[6];
  unsigned char i;
  unsigned char b;
void rx_handler (void);//declare the ISR function.HIGH
#define BUF_SIZE 25
 * Step #1  The data is allocated into its own section.
#pragma idata bigdata
char data[8][BUF_SIZE+1] = {
  { "You Typed: 0\n\r" },
  { "You Typed: 1\n\r" },
  { "You Typed: 2\n\r" },
  { "You Typed: 3\n\r" },
  { "You Typed: 4\n\r" },
  { "You Typed: 5\n\r" },
  { "Invalid key (0-5 only)\n\r" }
#pragma idata
//location of the ISR.(HIGH)
#pragma code rx_interrupt = 0x8
void rx_int (void)
  _asm goto rx_handler _endasm
#pragma code  //return to default code section
#pragma interrupt rx_handler
b = getcUSART();
if(b == '1')
	c[0] = b;
	i = 1;
else
	c[i] = b;
	i++;
  //Get the character received from the USART
while(!DataRdyUSART());
 c  = getcUSART();
 c1 = getcUSART();
 c2 = getcUSART();
 c3 = getcUSART();
 c4 = getcUSART();
    //Clear the interrupt flag
    PIR1bits.RCIF = 0;
void main (void)
ADCON1 = 0x0F;
TRISCbits.TRISC5 = 0;
//LED
TRISB = 0;
  OpenUSART (USART_TX_INT_OFF &
             USART_RX_INT_ON &
             USART_ASYNCH_MODE &
             USART_EIGHT_BIT &
             USART_CONT_RX &
             USART_BRGH_HIGH, 25);
PORTBbits.RB3 = 1;
PORTCbits.RC5 = 1;
Delay10KTCYx(50);
while (BusyUSART());
	//value sent
	putcUSART(0x31);
	//value sent
	putcUSART(0x32);
//value sent
	putcUSART(0x33);
	//value sent
	putcUSART(0x34);
	//value sent
	putcUSART(0x35);
Delay10KTCYx(50);
PORTBbits.RB3 = 0;
PORTCbits.RC5 = 0;
/* Enable interrupt priority */
  RCONbits.IPEN = 1;
  /* Make receive interrupt high priority */
  IPR1bits.RCIP = 1;
  /* Enable all high priority interrupts */
  INTCONbits.GIEH = 1;
  /* Loop forever */
 while (1)
and here's a code i have been working on for the communication between the remote system and PIC...
  • File1-AAS4.pdf
Well, it looks to be doing something completely different.
Try getting it working without interrupts first, something like,
char GetByte(){
    return(getcUSART());
    while(GetByte()!=0xce);     //wait for header byte
    checksum=0xce;              //initialise checksum
    for(i=0;i<4;i++){           //now get next 4 bytes
        c[i]=GetByte();
        checksum+=c[i];
    if(checksum==0xff){
        //got a valid package so send acknowledge
        //and use the data
 c  = getcUSART();
 c1 = getcUSART();
 c2 = getcUSART();
 c3 = getcUSART();
 c4 = getcUSART();
if(c == ':' && c == 0xCE)
	respond_to_command();
else if()
i was planning to attend to each incoming bytes individually...
I already did. What was wrong with the code I posted. It does exactly what is stated in the pdf.
char GetByte(){
        c[i]=GetByte();
        checksum+=c[i];
    if(checksum==0xff){
        //and use the data
care to explain in details about ur code?
thanks.
I made a function GetByte() so that you could do,
    c=GetByte();
//instead of,
    c  = getcUSART();
I used that function to wait until 0xce, the start of packet byte, is received.
I then read the next 4 bytes into an array. So they are in c[0] to c[3].
I also added the bytes up to calculate the checksum.
The checksum is the sum of all 5 bytes received, 0xce+add+cmd+data+chksum, and so it should equal 0xff. Actually, having just looked at the pdf again the checksum shouldn't include the 0xce. So, change to,
    checksum=[COLOR="Red"]0[/COLOR];                 //initialise checksum
        c[i]=GetByte();         //store in array
        checksum+=c[i];         //and add to checksum
    if(checksum==0xff){
        //and use the data
sorry.. i think got it already.
i got it already.. becoz i confused with the statement that states that add ALL DATA, including checksum.. i thought ALL DATAS inclusive of the start byte.
Address. And the checksum will be 0xff (add+cmd+data+chksum) with the modified code.
    s  = getcUSART();
    while(s !=0xCE);     //wait for header byte
    checksum=0;              //initialise checksum
        c[i]=s;
if(checksum==0xff)
//OK
unsigned char m;
m = (0xFF - (c[2]+ 0x06 + c[1]));
	//value sent
	putcUSART(0xCE);
	//value sent
	putcUSART(c[2]);
//value sent
	putcUSART(0x06);
	//value sent
	putcUSART(c[1]);
	//value sent
	putcUSART(m);
        //and use the data
else{
//NOT OK
unsigned char m;
m = (0xFF - (c[2]+ 0x15 + c[1]));
	//value sent
	putcUSART(0xCE);
	//value sent
	putcUSART(c[2]);
//value sent
	putcUSART(0x15);
	//value sent
	putcUSART(c[1]);
	//value sent
	putcUSART(m);
mike, i did something like this for the acknowledgement. but i keep getting "CE CE 15 CE 4E" as an acknowledgement if i send "CE 05 41 01 B8"
