You guys are just part of the conspiracy to keep cheap power from the hands of the public!
You figured out that I own stock in First Energy? Damn!
Ron
Secondly any alternator that requires power supplied to it, to excite it to start with can not be called efficient, a little loss under the bonet of a car dont matter much but in a RE situation its a huge difference.
How about the fall in level as the waves recede? Is there some mechanism to ensure the torque is always in the same direction, or is the torque (at least approximately) sinusoidal with reversing direction?the alternator will be driven by the rise in water level caused by waves at the beach.
Good info tcmtech. Just for a point of reference, a standard automotive alternator puts out 60A @ 14V = 840W. 1hp = 746W, so it takes over one hp to turn your car's alternator to full output, not counting losses in heat or the belts...
Car altys usually produce max current around 6k rpm, so 1:1 ratio would probably work fine.
