What is a "uv meter movement" ?
The meters that go across shunts are usually 50 mV, full scale.Need a diagram for building an amp meter using a uv meter movement
in the range of 0 to 2 amps
I will try your setup thanks for the info
DALEE
As this is probably a moving coil meter, the basic movement will be linear.Most Analogue VU meters are about 200 to 250 uA full scale.
And Typically around 100 uA at the -3 Db point.
There Scale is NOT Linear, so it will not make a very good amp-meter.
Re-drawing the scale will fix the linearity problem.
OK, I am a bit surprised at that but I will defer to your greater knowledge.Mine are Also Moving Coil meters. But Definately NOT Linear.
And the scale will look a bit odd.Reguardless of that, it can be used as an Amp-meter and Calibrated accordingly.
