Completely agree. But designer beware. Now not only do you need a 12-bit-accurate voltage reference for the D/A system, you also need one for the A/D system for "full accuracy".It's best to make the 7 segment display an actual volt meter so that it actually measures the output rather than assume the output is some set level based on the count setting because output loading will affect the true output voltage. That would be done with a separate ADC.
