Analog voltmeter does not go back to zero
remzo
Hi all,
I wanted to use the output of a DAC pin of the ESP 32 to control a voltmeter and use it as a display.
This almost seemed to work but suddenly the volt meter has chosen a new 'zero' at .5 volt.
The ESP32 sends out different voltages and the meter responds. But not so accurate since .5 is the new zero.
Can I somehow reset this meter?
Solution
The mechanical "zero adjustment" mechanism has been disturbed, I guess by your fingers when you picked up the meter.
Try moving the the part indicated by the red arrow.
When that part is vertical, the meter pointer should be at zero.
Does the meter not go back to zero when the DAC signal is physically removed?
As crutschow's question is "Does the meter NOT go back to zero" when the meter is disconnected from the DAC do you mean that it does NOT go back to zero ?
Les.
It does not go back to zero indeed. In the photo the volt meter is disconnected.
If I switch + and - the DAC signal makes the meter go to zero (and it tries to go even lower).
Solution
