zachtheterrible
Active Member
This is the artwork for a 900MHZ transmitter using a pre-built RF module. The pins lined up horizontally is where the circuit plugs in. The last pin on the right is the antenna pin. The antenna is a whip antenna. I have quick question:
Did I do it correctly? The datasheet said that there should be a groundplane horizontal to the vertical antenna, which is a piece of wire in this case.
