Cicero
Active Member
For sure, I can definitely see the potential in using both an NTC and PTC together in series, NTC for initial startup inrush, allowing a smoother ramp in current, and a PTC for overcurrent/fuse action.Cicero:
I thin the Surge Stopper Devices https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAA&url=https://www.linear.com/docs/40955&ei=czPwVI2YOYvlsAS3v4H4Aw&usg=AFQjCNEPgX0-Y6NsfPSuHXTjExaBnytS8A&sig2=IKNZiT6ZOX1el2UNCPMk2A&bvm=bv.87269000,d.cWc&cad=rja from Linear technology is more appropriate for these low power devices.
PTC's and even NTC's are very finicky to work with.
In a Fire Alarm panel I purchased each Class two output was protected with a PTC. You had a choice of PTC's or fuses.
Because of inrush currents some strobes would not operate., The manufacturer fixed the inrush problem in some devices, I had some of each. Class II supplies are around 100 W.
PTC's for motors work nicely because the overload characteristics are well known.
NTC;s were used in tube televisions. PTC's were used to run the degaussing coils.
In-rush current limiting and surge suppression are not quite the same and I had to use both. A Y-Delta motor starter is sort of a soft start.
