Any SVG File Experts Here?
For The Popcorn
Most Helpful Member
When I export an SVG file from EasyEDA, with all layers set to black, some viewers display the file correctly. However if I open the file in Visio, it appears as a blank screen until I highlight the entire area and set the line color to black, when it appears as expected. If I import the EasyEDA file into Glowforge laser software, it appears blank, and says there's nothing to cut.
If I save the file from Visio after changing the lines to black and import it into Glowforge, it appears as it should.
I looked at the EasyEDA file and messed around with the STROKE command, but couldn't find any combo that made the file appear as it should in Visio, and therefore work in Glowforge without extra steps.
I'm hoping to find what needs to be edited in the EasyEDA file to solve this problem. Attached is an EasyEDA SVG file of a 100mm x 100mm open square - change the extension to svg. If anybody is knowledgeable in this subject, I'd appreciate your advice.
  • 100mm sqr_2024-11-17.txt
This is what I get when opened as is in Inkscape.
https://inkscape.org/
Thanks. Can you measure the square to verify it's 100mm x 100mm? The SVG has a boundrvy frame around the area a little larger than the square.
I guess a square was a poor test example
Here's a better revised test - a square + circle. Change the extension to svg. The image shows what I see in Visio after making the lines black.
  • 100mm sqr + circle_2024-11-18.txt
Both of your test files open showing black lines matching your reference image.
Details of each element indicates the selected object is 100.254 mm overall, with a line width of 0.254mm, or 100mm to the center of the line
Wierd. Unfortunately I only have access to Glowforge at a makerspace so it's hard to test.
I'm working on a tutorial on using Lego Technic frames for enclosures with EasyEDA on Jon's Imaginarium. The fact that EasyEDA SVG files may require some manipulation to work throws a monkey wrench into my plans.
I'll post EasyEDA footprint templates soon that make laying out an enclosure simple.
I use and SVG program called Boxy. If I open the EasyEDA svg file there, select all, and click "convert stroke to path" and re-save the file, it appears to behave properly.
