Wow that's an impressive response! Went to bed with 3 posts, wake up and we're up to 19! Thank you to all who are interested in helping me![]()
No probs EF.
That sounds greatI appreciate the efforts to keep costs to a minimum, however the very reason I'd like to build something myself is not to save money (well maybe a little) But more to the point it's about building something rock-solid reliable. And also I enjoy the learning process along the way rather than buying manufactured end products. So don't worry so much on the most cost effective solution, rather I'd like the best solution to build a constant current adjustable DC load tester.
That will be fine#8, The only practical heat management for my application will be the use of very large heatsinks and fans
That sounds great too.#16, That does depend on the size of the bank I'll be testing, It should be designed in such away that it can handle hours of abuse.
Sounds like you know your way around the Arduino, so writing the PWM sketch should not be a problem, besides which there are quite a few Arduino coding experts on ETO who will no doubt help to sort any problems.#18, That looks like a real nice idea you have there! While I'm not knowledgeable enough to create a program for an adruino for such an application, I certainly have experience editing and know all the basics when it comes to working with arduino's.
Too true: I would love to be there helping to build your megga machine.Spec, I could be wrong but I think you're liking this man-sized project aren't you?After reading my latest post I imagine you have a fair idea of what I'm after design wise. Do you think the idea you posted in #18 is the best solution? It sure looks great to me!
I do think that the post #18 approach would be the one to go for if you want to build from the ground up. It will also give good performance and maximum flexibility. If you like, I will have a look at a more detailed circuit for you to consider.
If I can give a piece of cracker barrel advice: the first stage of your project would best be to sort the mechanical side: case, heat sinks, fans, high-current cable, terminals/connectors etc, so that you have a solid platform for developing the electronics.
Also, may I suggest a solid walnut cabinet with titanium fittings to give the unit a touch of gravitas and an optimum balance between traditional and modern.
spec
