Hi all,
My 18" Philips 181AS TFT monitor isn't working so well. The inverter wasn't working, found the SMD fuse open and replaced. All lamps light up now, but the brightness seems too low - the whites aren't as bright and fresh as they should be. Along with this, the inverter transformers are squealing at a high-pitch.
It has 4 lamp outputs, with each pair at either end being run by a dual-output PWM controller. Each lamp has it's own circuitry after that, mirroring the other 3. I can supply the datasheet for this controller if necessary, but have no schematic for the inverter (TDK TAD383).
The start-up voltage for the lamps must be reaching the right levels as they fire up alright, so I don't know what could be wrong to have them run improperly after that. Yesterday I removed the lamps to view them whilst running the monitor. At one point I found just tapping the board ever so gently caused the lamp circuit on that side to shut down. Seems that side is sensitive anyway, as before that I found just touching a screwdriver tip against one core of a particular transformer will shut the circuit down on that half of the board (core sparks a bit first, as they all do). Not so with the other transformers though. Anyway, after moving the lamps about some more, tapping and banging the PCB wouldn't shut it down, so maybe a lamp connector wasn't in properly (although I'm sure they all were).
It's got me very confused. I wondered if a SMD device was cracked or internal breakage was present in a component, but banging the board and flexing it won't make that half of the inverter shut down again.
I'm at a loss as to what to do next. Any ideas?
Thanks,
James
Thanks,
James
