Thanks, So it is impossible to reach that freq with the said chip.
I have seen a circuit used 555 IC as an Astable mode. It had a 1PF ceramic connected to pin2 and ground, It used a 82k resistor for pin6 and pin2&6, the resistor which was connected to pin7 and the positive rail was a 6.8k, I guess those values give a freq of almost 8Mhz, right? If so , is a 555 reaches to that high frequencies at all?
thNKS
So it would be a trouble for me to find a chip to generate a square or ramp wave at 10Mhz, right?
High speed Cmos (74HCxxxx) works up to about 30MHz. But nobody makes a 74HC4047. Use another type of high speed Cmos oscillator.
Thanks for all inputs,
Do you know any?
The power supply is 12V so I think I will have sort of problem using 74HCxxxx chips, right?
What do you mean by "Use another type of high speed Cmos oscillator"?
