ATMega168 Tachometer help using LM2907 chip
Hey all i am trying to make a tach that i can read the cars RPM's. I am only looking for the chip to see what the RPM's are and not display it out to the user.I've draw up how i think it should be hooked up but I'm still now 100% sure.
I am using the LM2907 chip and tapping into the tach wire from the ECU of the car. I'm looking at it as if the RPM's are 200+ then the car is started. Anything lower then the car must be off. I'm checking because i will be remote starting the car and need to know when the stop cranking it.
https://www.electro-tech-online.com/custompdfs/2009/03/LM2907.pdf (Page 8)
Any help would be great!
David
David
