Why?I have to build a 5 band equalizer using microcontrollers.
This is an assessed project. It is compulsory to use microcontrollers for this purpose. I got a few schematics. The best one had used LM833. That is nowhere to be found in my area right now. NE5532 is the substitute I choose.
What I need to know is whether this would work?
Can the equalizer work alone or does it need an amplifier as well?
I need it to do both.Both of those are opamps, not micro-controllers.
Depends what you want to do with it, it can do either.
What he should have said is:I have to build a 5 band equalizer using microcontrollers.
Yes thank you for the clarificationI think that there may be a translation problem here.
"I have to build a 5 band equalizer using integrated circuits."
I think that the mis understanding goes like this:
An op-amp is (usually) a type of integrated circuit.
A microcontroller is a type of integrated circuit.
BUT, an op-amp is NOT the same as a microcontroller.
https://bestengineeringprojects.com/5-band-audio-equalizer-circuit-using-lm833/ this is what I gotI was about to suggest "microcircuit" instead of microcontroller.
In that case, the 5532 is an excellent choice for general purpose audio work. It is old, but readily available, and it is much better than most other opamps of its time.
Almost all 5-band or graphic equalizers use opamps to make up for the signal attenuation through the filter components. In this way, the output signal level is approximately equal to the input signal level.
For more than three bands, a common approach is to use opamps to form a synthetic inductor as par of an L-C filter circuit, with one or two opamps per frequency band.
Please post a link to that project page or schematic.
ak
Can you please point out the adjustments need to be done?With a few adjustments, a 5532 can be dropped into that schematic.
Yes, and I have to build the circuitIs this a school project?
No.Can you please point out the adjustments need to be done?
Thank you. Will post future updates.No.
But if you put some effort into the project, we will be glad to review your work and make suggestions.
ak
Thank you for your insightI second Analogkid’s suggestion: use a +/- 12 volt supply.
A +/- 15 volt would be slightly better.
Thank you for your insightYou could use switch capacitor filters -
Understand How to Use Switched Capacitor Filters to Save Space and Improve Filter Performance
Use switched capacitor filters to lower parts count and get greater accuracy, temperature stability, and reliability compared to passive or active RC filters.www.digikey.com
Interface - Filters - Active | Electronic Components Distributor DigiKey
Interface - Filters - Active are in stock at DigiKey. Order Now! Integrated Circuits (ICs) ship same daywww.digikey.com
Or google "audio equalizer FFT".....
Regards, Dana.
Thank you for your insightYou might want to consider a circuit using gyrators (which emulate an inductor), since the circuit can be somewhat simpler, such as discussed here.
No, those are OpAmps and they have nothing to do with microcontrollers.I have to build a 5 band equalizer using microcontrollers. I have chosen NE5532 for the job. Is this sufficient enough? Do I need to design an amplifier as well? If so why?![]()
