mushroom187
got the data its as follow, foward voltage : 3.2 - 3.7
reverse voltage : <=30
max power dissipitation :80 mw
max peak foward circuit 75 ma
reverse voltage : 5-6 volts
it comes with resistors to work with 12v ,
what can i use as power supply instead of battery?
also the leds are daisy chain, mean from 1 led goes to the next and so on last
led on chain has the pos and neg so i connect that to pcb board, i have three chains, they
all connect to pcb board,, the pins for the led also connect to pcb board,, splicing station
i cant upload pics 4 some reason,
u said MIN voltage input is 4v on lm386 chip, can u pencil draw a quick diagram with using mic, capacitor thanks
