Huh? It has everything to do with power measurement, unless, I guess, you are an audiophile...
Which is what the thread is about
To try and get a clarification on the original question (as I understand it, at least) am I correct in saying we are all agreed that "Average Power" and "RMS Power" are the same thing. Even if the nomenclature is not correct, these two terms *don't* represent different measurements that might produce different results when carried out on the same piece of equipment?
However, you 'could' use the 'average' from it (as you've done below), which is why 'average' is a confusing term, and has no bearing on the power output measurement of an amplifier.
If you run a 100 W lightbulb for 12 hours per day and leave it off for 12 hours per day, the average power usage over a day is 50 W. Is that confusing?
Here's an interesting question:
If you have a periodic positive voltage feeding a constant current load, do you use the RMS value of the voltage or the average value of the voltage to calculate the power dissipated in the load?
Your question is ill-posed. Do you want to know how to calculate the RMS power, or the average power? MrAl showed how to calculate the average power, assuming that's what you wanted, but you didn't say that was what you wanted.
I am talking about real (average) power since here are no reactive components mentioned.Your question is ill-posed. Do you want to know how to calculate the RMS power, or the average power? MrAl showed how to calculate the average power, assuming that's what you wanted, but you didn't say that was what you wanted.
How are you defining RMS Power and Average Power?
I guess you are defining Average Power as usual, but what about RMS Power how are you defining that?
