Just don't try an use it to check the 20Mhz oscillator on the PIC.B&K MODEL 1476A 10 MHZ TWO CHANNEL OSCILLOSCOPE Would this scope be a good starter for use with a pic 12fxxx and 16fxxx and 18fxxx
I was thinking about building the supper probe
That's called a "fork".![]()
B&K are cheap scopes, and 10MHz is almost useless.
This seems a typical American attitude?.
I got a 20mhz 1 now the only scope I have used is a winscope that use's the sound card of my pc it is slow but you could tell if a pin was going low to high thanks for all the input. I read the book with this scope and it said you could sample faster if you use ONE CHANNEL that the rating is for TWO CHANNEL can that be so?? Well any way I now get to use my probes I made for when I got me a real scope. Nigel all of us American's have attitude's now that we are broke.This seems a typical American attitude?
Two channel scopes have have two ADCs. In single channel mode, many scopes will take the unused ADC and interleave it's sampling with the other ADC to get double the sample rate. For these scopes, it is the single channel rate that is (almost) always advertised because it looks much better than the dual channel rate so you have to read the specs carefully and dig a bit deeper sometimes.I got a 20mhz 1 now the only scope I have used is a winscope that use's the sound card of my pc it is slow but you could tell if a pin was going low to high thanks for all the input. I read the book with this scope and it said you could sample faster if you use ONE CHANNEL that the rating is for TWO CHANNEL can that be so?? Well any way I now get to use my probes I made for when I got me a real scope. Nigel all of us American's have attitude's now that we are broke.![]()
