Cloud9 said:Oooh more brains! Thanks all.
Yes, Lead-Acid or Gel-Cell. specs for the battery are 12VDC 33mAh
RadioRon said:You might also want to read some application notes from a major lead-acid battery maker on how to charge their batteries.
Is the battery powering something while you are trying to charge it, or do you remove the battery from the load and connect it to the charger? If it is still connected to the load while you are charging it, what is the load?Cloud9 said:The problem seems to have appeared when we changed battery types. Similar specs but a different manufacturer. I wonder if its just coincidence.
Roff, what do you mean? It is a valid battery usually between 10-11V. As far as current and load resistance, I dont know. I wish I had one of those fancy batt analyzers right about now.
I think RadioRon is talking about 13.8V across the battery. I don't think we know enough to tell you how you can set the charger without a battery in place. I realize that puts you in a difficult position. Maybe we can figure it out when I do some more simulations.Cloud9 said:Oh sorry Roff, I see. No load, in any case we will disconnect our device from the battery.
Also just to clarify, where I should be measuring my 13.8ish volts when adjusting the open circuit? I used the bottom of R17 but I fear that wasnt the appropriate place.
I appreciate the time you guys have taken to help me out!![]()
Brian, we've got two Rons in this thread. maybe you could be more specific.Brian Hoskins said:Ron - does the off load output need to be set at a slightly higher voltage than that required to charge the battery fully in order to take into account the headroom of the series pass regulator circuit?
I see a pnp transistor is used as the series pass device, which I think gives it low-dropout functionality but I'm not quite sure what this drop-out figure would be.
Brian
RadioRon said:Thinking back, didn't Cloud9 also say many posts ago that he measured 13 volts on all terminals of Q4. If this is true, I wonder why. One explanation might be that Q4 is blown and shorted.
Puzzled.
Roff said:Brian, we've got two Rons in this thread. maybe you could be more specific.
The PNP is a Darlington, so it will always have at least ~0.7V Vce(sat).
