Yes, it does. It changes depending on the current level being drawn as well as the current charge left in the battery.paparts said:does the battery voltage chang whn you supply it to a circuit?
bananasiong said:9 V battery has very low capacity. AAs last much longer. For controlling the speed, use PWM.
9V batteries drop to below 8V very quickly so the regulator will loose regulation.paparts said:im powering a mobot. I am using a 7805 to supply for the microcontroller and for an ic(LM339), and 5 ir's. LM317 for an adjustable output for the motor driver.
