Bcd counter + bcd to 7 segment converter in one IC
Kurt Andersen
Does anyone know if you can buy an IC with both bcd counter and a bcd to 7 segment converter?
Im trying to make a counter that is very tiny, and can count from 0 to 99.
Look at this option.
  • cd40110b.pdf
On the other hand, used to be you could use the TIL311: BCD/Hex input, and is the display. Then you can use the counter of your choice which is even more important. Trouble is, the TIL311 was pricey when it was available.
If you have more than one digit you will either need two chips or multiplex the 1 chip between the displays.
