Grossel said:I think that using a count-down decade counter where you can input bcd directly (or via enable-gates) to "set" input might reduce the numbers of components.
That works as long as you use BCD decade counters, as you stated earlier. The count down approach can use either a binary or decade counter.It might reduce the part that determines when to stop counting, depending on whether one tries to build it with descreete gates or just use a mag comparator. But the control of the "count up" solution is simpler: assert the BCD code at the input to the mag comparator, toggle the reset to the counter.
You are correct. I had a brain malfunction.Disagree. For a single BCD decimal, a binary counter would work either way. For two or more decimals, it fails either way.
