High I am making a magnesium cell using magnesium ribbon as the Anode, I will be using sodium chloride as the electrolyte but wondered if there was anything better than carbon/graphite for the cathode?
-No-...anything better than carbon/graphite for the cathode?
Sure, I have already spun up saltwater for other things, its a real eyeopener how much crud is in sea water lol.Can you manage/ask your dad's 22000G and find if seawater becomes less salty by the surface layer than at the bottom after a good spin ?
Do want the SG from different layers? The tube length for the sample is a max of 110mm, I have two options for configuration.
!) Fixed 45 degree tube
2) moving tube where its angel is dependent on the force, I normally use this as it prevents and spills from the tube
Finally any particular temperature? its a heated/cooled centrifuge so I can spin anywhere from a temperature of -32C to +130C
I was unaware the water and NaCl formed an azeotrope. I think a citation is needed for that conjecture. Distillation of salt waters is an established means of creating potable water. It is by a similar process that we get rain.LG said:... you wont remove all chloride ions simply because water and sodium chloride form an azeotrope, you can reduce it and alter the specific gravity but you wont get it potable..
Hi John your correct in terms of distillation only weak azeotropic bonding is present and the heat easily breaks the bond, the same isnt so true for separation by centrifuge, BUT I dont know how true this is over 22G as I have never tried.This thread has used a couple of confusing terms that seem to be getting intertwined. According to Michael Faraday the term "anode" in an electrochemical cell applies to the electrode at which oxidation occurs. In terms of positive and negative of a battery, it is the negative terminal. Similarly, the cathode of a battery is the positive terminal. Wikipedia makes the distinction that those labels apply during discharge. Presumably, the magnesium cell you are working on will be a primary cell, so recharging is not an issue.
LG properly named the magnesium ribbon in his proposed cell the "anode." But others (e.g., post#12) have referred to the positive terminal (carbon rod) as the anode. That is a common misuse of the term, and I have even seen it is Wikipedia. I don't find using the term "anode" for the negative terminal of a primary battery at all confusing, but perhaps calling the terminals negative or positive, as appropriate, would avoid confusion.
John
Hmmm. According to the Oxford English Dictionary an anode is "a positively-charged electrode".According to Michael Faraday the term "anode" in an electrochemical cell applies to the electrode at which oxidation occurs. In terms of positive and negative of a battery, it is the negative terminal. Similarly, the cathode of a battery is the positive terminal.
Azeotrope is a bit misleading in this context, similar to the cell and anode I guess.
If you look at the mid Atlantic conveyor where salt and fresh water are under high pressure and form a layer, the layer isnt exactly salt/freshwater, there is a tiny layer at the interface where they meet, this layer isnt as salty as the water above it and isnt as fresh as the water below it.
I offered to try and get dad to spin some up at work on the beast they have, I am sure there will be a point where you could separate it out, but for sure its above 22,000g as I have tried this, I have also tried to clear used engine on the work machine and it does kind of clear, but it rips things apart and the oil isnt as good after. I asked how high it could go but dont have a answer, apparently you have to be precise on the set up before you get an answer to that, I know on my machine it has to be carefully weighed and balanced on all sides when spun over 500G or it cuts out.
The length of tube etc etc etc all make a difference on the bigger machines as to how high they can go, Common sense would say if the tube was long enough and you could spin it up fast enough you will get a fresh and salt water layer,but from a practical lets try it point of view it becomes less simple.
The other point with Azeotropes is most can be broken, for example Ethanol and water can be broken by magnesium sulphate and the final drop of water removed with sodium wire. But distillation alone will not break ethanol and water, I am not entirely convinced that going as high as you can speed wise is the best way. it could well be that over a certain force it becomes counter productive, I will look for a paper that might help but I am not sure there will be much on it.
Most will deal with water and salt distillation and there is no problem separating that way. The best I can do is try it on a better machine, I cant use the bigger one as its in a sealed room etc etc due to safety if it breaks apart!
My first one went upto 12,000G and when the spindle broke it wrecked the case as well. The much much bigger machines at his uni are far more dangerous if parts give out, I do know the tubes cost over £35 each for tests over 35,000G.
The anode, cathode thing is utterly confusing so I tried to use the chemistry excepted way of the anode being the magnesium etc. But it is one area I get confused on a great deal! our fishing boat has a zinc sacrificial anode, but to my thinking its actually a cathode! Maybe this is one case where plus and minus are better terms
Source: **broken link removed**
An azeotrope (pronounced /əˈzi.ətroʊp/ ə-ZEE-ə-trope) is a mixture of two or more liquids in such a ratio that its composition cannot be changed by simple distillation. This occurs because, when anazeotrope is boiled, the resulting vapor has the same ratio of constituents as the original mixture.
