digitalrain
Hello, I just registered here, and I hope you can bear with my extreme lack of knowledge.
Basically my project is this: testing the germination of seeds exposed to an electrical current.
My setup is extremely simple, but I seem to have run into a problem. What I expected to do was simply run a current through a sheet-like conductive medium, with the seeds resting on top of that medium. So, I connected a power supply to the ends of a sheet of aluminum foil, and I'm not reading any voltage.
This is where my lack of knowledge should become blatantly obvious...I'm pretty much stuck as to what to do. In all honesty, I'm not sure I'm even going about this the right way, and perhaps this project was a little ambitious given my level of competence in the subject. Anyway, I'm using this power supply:https://www.allelectronics.com/cgi-bin/item/PS-637/480/5V_8A,_3.3V_4A,_2.5V_2A_POWER_SUPPLY_.html
and I've tested it with LED's to make sure it's functioning, and it seems to be.
Any help on this would be greatly appreciated, thanks.
