So, you may reasonably ask yourself this; if the author of a serious engineering text writes the following:
IC=Is*e(---)
why would he write Is if he really means Ies? He already has the coefficient that references the emitter, why would he change the notation? I doesn't make any logical sense. I doesn't make any mathemetical sense. It's very, very common in mathematics that if there are two terms, and one term does not significantly affect the result, that terms is just left out of the equation for simplification. The remaining terms are retained exactly as they were before the equation is simplified.
No! If the author means Ies, then he writes Ies. He doesn't arbitraily change the notation. These are two different coefficients.
IC=Is*e(---)
