A bit more info would be useful. Where did the photo come from? That looks like the footprint for an ESP module.
You didn't answer the question, where did the photo come from?
Possibly a Microchip RN4020? Those have two ground connections at each end.
Without seeing the overall PCB so tracks can be traced, it's purely guesswork..
That's still the case.Without seeing the overall PCB so tracks can be traced, it's purely guesswork..
It's probably simpler (and cheaper) to have the same firmware on all the model. A quick check at the beginning can easily ascertain if the module is there or not.If the firmware in the onboard processor isn't set to talk to the module, then no information will be available.
Even if you found the right bluetooth module, it may not work.
However, there might be other hardware differences and without comparing the two (different) boards, no way to tell.
It's unlikely that a large scale manufacturer would use off the shelf Chinese modules, they would simply buy the IC's and build their own - one reason would be that it's to prevent people doing what you're wanting to!yes that's exactly my initial thought.. it's a cut down version for lower cost..
the board having the bluetooth are exactly the same, so i guess they didn't
spent time to make different firmware for each version.
so since we can't find a suitable module i assume it's custom built bluetooth.
thanks guys.
It's very likely that the module is just a simple copy of the chips datasheet, and if you could find a cheap module that uses the same chip, it could be worth giving it a try (although you'll probably have to make your own connections).
SDA and SCL are I2C labels. TXD and RXD are UART labels. You might look to see if there are pullup resistors on those two lines. They would be needed for I2C. Although that wouldn't be an absolute indicator, they could be populated on the BT module.
One thing you might try is looking for any activity on those pins with a scope or logic analyzer.
Are there any other parts connected to those pins?
There are literally hundreds, if not thousands, of different mass-produced Bluetooth modules.i guess there's no such commercial
bluetooth module with that pinout right?
