electrookie
Greets all...
I am looking for a circuit to boost 12Vdc(car batt.) to 100Vdc. I find various circuits that give me ideas but not yet found the "right" idea. It seem's that these "charge pumps" are the way to go for this. As I understand, this is due to the lack of inductors. I do find plenty of circuits to boost current and this seems relatively easy to do so I am thinking of using some kind of charge pump design, whatever its current is, then running that thru the current amp. I only want 20 amps or so
, more likely just need a few amps, but want as much available as I can get.
I want to avoid converting the 12Vdc to an AC voltage only to have to convert back to the desired DC. That seems to me, a wasted step, wasted design, etc.
I will keep searching, but I throw this out to you all to see if any one has an idea of where I should go with this.
Thank you all for your help on my other projects to date. This seems to be the Forum to go to as I get issue resolving help from you in here
. So thanks again...
