BOSE quiet comfort 25
DASSAS
Bose qc 25 headset- on last few Delta flights used two prong adapter and the sound is barely audible. We have two sets and both behaved the same way. Does anyone know if Delta has changed something in their audio system that would cause this volume issue. The Delta headsets volume was fine.
Do they work OK using the same cable (less the adapter) with a normal audio source?
Did you have more than one adapter?
The "very quiet" effect is typical of the headphones having the left and right audio signals but no common ground; you only hear the difference between the channels.
How many contacts do the plugs on the Delta ones have? I've seen noise cancelling headphones on some airlines in the past, that have more contacts on the plugs.
