To a degree the bottom one in the outer jacket i can put up with on fully or off, i dont need speed control, yes it would be nice but isnt major.looks like a standard IEC mains socket.
Nah. With your obvious abilities I'm sure you could modify the mounting of an alternative motor, if necessary. Is a stirrer that critical, as long as it stirs at a controllable rate?
The black stir mechanism that stirs the inner jacket is vital, so is the speed control and unfortunately it isnt a set speed, it isnt on all the time. You monitor the organism and the phase its in, depending on the situation the stiring being on or off and the speed control is dictated by the sensors information of what the reactor is doing. This is i suppose one reason they charge £12,000 secondhand for the control unit
8 pins....
is it likely 6 for the stepper and 2 are control pins? all pins are highly likely to actually do something. I havnt come across any of these plug types with multi pins where all the pins are not used, not in bioreactors anyway. they tend to just pin up the connections they need
