Buck-Boost converter 12V battery to 13.8V 5A?
To do that you would obviously need a step-up/step-down module, as you need to do both.
Exactly what are you trying to do?, the mention of 13.8V looks like you've seen the nominal voltage of a lead acid 12V battery and are wanting to maintain that for some reason?. A low power transceiver should be designed to work from the battery 'as is', no need to do anything - just connect it to the car battery.
Something like this is about as near as you will get in an all-in-one unit.
That can take vehicle 12V in and give stabilised 12V, 15V or various other voltages out.
Some older stuff, while yes, designed to used "in a car", was not designed to used on top of a mountain where there are no cars - possible use #1 - I'm assuming you've heard of SOTA operation?
Other stuff is designed to be battery powered, but falls miserably short with just a small drop in battery voltage - possible use #2.
#3 - why do I need a reason, other than just out of curiosity?
There are several circuits for DIY jobs in QST/QEX/CQ magazines etc and I was curious as to whether there were any cheap modules around already built.
If your power requirement actually that high?, or would lower be OK - if so cheap modules are available:
You're considerably limited by your requirement for step up and step down.
One easy option would be to step UP (to say 18V) then step DOWN from there to 13.8V - but that's essentially what the step up/down converters are doing anyway.
Here's a 5A step up:
And a 5A step down:
Most low power rigs would get away with 2-3A, I prefer to be a little cautious and leave a little headroom 'just in case'.
A trawl through Ebay and the likes throws up plenty of 3A ones like your first one and I did come across a 5A one but it needed an input voltage of min 15V to supply the current and voltage, so kinda defeats the purpose.
As I've repeatedly told you, your requirement needs BOTH a step-up and a step-down, either a single module, or (as it more likely for 5A) a pair of modules. You can't step down from a car battery to maintain 13.8V.
A portable transceiver will probably get lots of hash noise from any buck/boost converter, they are all switching power supplies. From what I've seen, most portable transceivers (ie 5W to 10W) will operate ok down to about 11V, so a regular battery will do as-is. Put on a small solar charger if you want to maintain the voltage a bit longer...
