Buck-Boost converter
pisaac001
hi clever ppl .. i am designing a buck-boost converter on simulink... i have an input of 50v and i want an output of 12v.... using these parameters i have calculated the duty cycle which is 0.19...can someone plss help me calcuate the values of C and L in the circui.....RL is 5ohms...i have attached the circuit if the helps...
Whatever your circuit does, I don't believe it will give you +12V out.
Why are you trying to design a buck-boost converter? Unless you need a output voltage greater than the input voltage you only need a buck converter.
What is Rs?
whu!, glad you cleared that up, and I thought the Rs resistor was just to limit the short circuit created by the coil.
