Budgeting a Wallwart
Electroenthusiast
Active Member
I was just googling certain things, especially about the wattage of wallwarts. On what components does the wattage of a wallwart depend on?
Also, why is not possible for Cell phones to create a faster charging wallwarts instead of having a separate one for low charging and faster charging ones.
I mean, think of a 2A wallwart and 500mA wallwart. Internally what is different in them, and how does a same cell phone be compatible (for two different wattages) with different wallwarts?
Thanks. Here's a thread from me after many many days.
I support For The Popcorn 's views here. I have felt the same. The output voltage (of the faulty wall wart) was mains voltage, and i was also able to feel the tingle when i touched the pinout. To be frank, this also meant that there was an issue with the china made cheap wall wart.
No one disagrees with his point - it's perfectly normal to feel a slight 'tingle' with Class II devices, this is due to the safety components which are there to provide static discharge.
However, this doesn't mean it's outputting mains voltage - and in no way means that there was an issue with the device - it's perfectly normal, and a design 'feature' not a fault (it's to prevent the possiblity of a high static voltage building up on the isolated secondary of the transformer, and discharges this back to the mains/ground).
If you've still got the device you should find it, and check it properly, or throw it away (after taking it to pieces and posting the pictures) - assuming there is a problem with it?.
What I have said is that ~½ line voltage at extremely low current is a common characteristic of SMPSs. It doesn't indicate a fault nor is it dangerous.
A cheap SMPS could fail in a way that does put hazardous voltage/current levels on the output, typically because of shorts in a poorly made transformer, but this would feel like more than a tingle.
