patroclus said:is it possible to build a simple logic analyzer for up to 8Mhz resolution using Parallel port or USB ??
EPP supports that high rate??
patroclus said:"3) this sample is stored in a FIFO (large enough to handle data flow with software & EPP port) "
Which FIFO could I use??
Why not sent it directly from buffer to USB??
The problem is that I don't know if EPP supports that rate, and I don't know how to use USB,.. (I know very well how to control paralel port).
As long as buffering is involved, I guess a form of control is required.patroclus said:Using a PIC and sampling to its internal RAM memory would do the job??
the problem is getting enough memory..
At 5Mhz (0,2 us resolution) , if you only have, let's say 1000 memory locations, you will be able to capture 0,2 * 1000 = 0,2 ms. Right?? It's not much...
Is any PIC from microchip recomended??
Is any other aproach better??
The Z80, RAM,... is quite a lot of work!!![]()
With memory, you'll still need some form of memory controller, similar for the case of using buffers.patroclus said:Yes, I suposed PICs are not fast enough.. but Z80 neither (runs ar 3,45Mhz) :roll:
As data cannot be sent to PC fast enough at more than about 200.000 samples per second (at least, not easily), I thought of sampling and storing in some sort of memory (RAM?). Keep on going until memory is full, ans sampling ends. Then, sending it to PC via ECP/EPP with no speed restrictions...
Any ideas for aproaching ??
Better other way??
"I was thinking more in the tune of FPGAs."
what do you mean?? :?:
Thanks in advance!![]()
