cluelesshillbilly
I want to first thank you sincerly for y'alls help. The project is really broken down into a few small issues. Mechanically I can build anything but when it comes to high accuracy thermostats, intermitent switches, and making it all work I need Y'ALL! For the turner I am using a BBQ rotisery motor but because the motor turns 3 rmp I need it to come on for 15 seconds every 60 minutes. It motor is 120v and very low amperage. Secondly I could buy a thermostat switch( **broken link removed** ) but would rather use a electronic highly accurate thermostat in the vent return duct. I need 100 degrees F with no more than 0.5 degrees of error. I can make this system 120v or 12v depending on what I can do about heating the cabinet. I have several 12v fans at my disposal and had considered using a 12v window defroster style heater but then I saw this Incukit ( **broken link removed** ) on eBay and said I can build that if I knew where he got the ceramic elements.
