Calling a delay in C doesn't seem to work
I'm trying to simplify a program to send a number then a letter to a PC to test the labview program I've written but the PIC isn't doing what I expect. This is probably something simple as I'm kinda new to writing in C.
#include <htc.h>
__CONFIG(FCMDIS & IESODIS & BORDIS & UNPROTECT & UNPROTECT & MCLRDIS & PWRTDIS & WDTDIS & INTIO);
//Define Variables
int i,j,k,m;
int dlay = 100;
int ADCValue = 0;
int ADCState = 0;
const char Channel[4] = {0x01, 0x01, 0x01, 0x01}; // AN0 only, repeated on all channels (test mode)
//const char Channel[4] = {0x01, 0x05, 0x09, 0x11}; // Channel select: AN0, AN1, AN2, AN4
//const char Ident[4] = {0x31, 0x32, 0x33, 0x34};	// Identifiers are ASCII '1', '2', '3', '4' to test
const char Ident[4] = {0x01, 0x02,0x03,0x04};		// Set Identifiers
void init_comms(void) {
	CMCON0 = 0x07;	//Comparators off. Digital I/O
	PORTA = 0x00;	//Clear PORTA
	PORTC = 0x30;	//Clear PORTC
	TRISA = 0x1F;	//Set RA4 and RA5 as outputs
	TRISC = 0x20;	//Set RC5 as an Input, RC4 to an Output
	//Desired Baud Rate = 9600, Fosc = 4MHz
	//Fosc/[16(n+1)] = Desired Baud Rate; where n = SPBRG
	SPBRG = 25;	//Set baud rate to 9600
	BRG16 = 0;	//8-bit Baud Rate Generator is used
	BRGH  = 1;	//High speed
	SYNC  = 0;	//Asynchronous mode
	TXEN  = 1;	//Transmit enabled
	SPEN  = 1;	//Serial port enabled
	CREN  = 1;	//Enables receiver
	RX9   = 0;	//Selects 8-bit reception
	TX9   = 0;	//Selects 8-bit transmission
	RCIE  = 0;	//Disables rx interrupts
	TXIE  = 0;	//Disables tx interrupts
	PEIE  = 0;	//Disables interrupts for CPU
	//ADC Initialize
	ANSEL = 0x00;	//Set AN0, AN1, AN2, AN4 as ADC Inputs
/*	ADCON0 = 0x01;	//Turn on ADC
					//Bit 7 - Left Justified
					//Bit 6 - Use Vdd as ref.
					//Bit 4:2 - Channel 0
					//Bit 1 - Do Not Start
					//Bit 0 - Turn on ADC
*/	ADCON1 = 0x00;	//Select the clock Fosc/8
void putch(unsigned char byte)
	//output 1 byte
	while(!TXIF)	//set when register is empty
		continue;
	TXREG = byte;
void delay(void)
			for (i = 0; i < dlay; i++)
				for (j = 0; j < 255; j++) {};
void main(void)
	k = 0;
	INTCON = 0;
	init_comms();
				PORTA = 0x20;
				putch(0x00);
				putch(0x01);
				delay;
				putch('A');
				putch(0x02);
				delay;
				putch('B');
				delay;
				putch(0x03);
				delay;
				putch('C');
				delay;
				putch(0x04);
				delay;
				putch('D');
        		PORTA = 0x00;
}	//END
Instead of having to write the for loop between each putch I'm trying to call the delay, but the program just runs at top speed and the serial port cannot keep up. The only delay is from the for loop I've left there.
Call the function with "delay();". You forgot the "()".
Also, i'd check the documententation of your compiler. There has to be a better way to check if the uart (be it hard or software uart) is ready to receive new data to send in stead of hard-coding a delay.
