I just thought that i'm not really right. When cap is energized potential difference between cap's plate and voltage source decreases, so speed of last electrons decreases to, so they will move slower and slower infinitely? Or no? Even if charge is discrete, electric force acting last electrons can vary depending on distance from charge stored on cap's plate, so last electrons will slow down infinitely while moving to cap (or from it on other side, but let's forget about other plate)? Last electron will newer get to cap? If space-time or energy is discrete itself it will stop after some time, but i don't know if it is. However this small movement will became indistinguishable from thermal noise much earlier.
In answering questions like this, we make a model, and then the solution, based on the model and the included assumptions gives us an answer. Once you are convinced that the model you are using is good enough, then the answer you get is the one you accept as fact. But, the real world is never exactly what your model is, so there will always be some doubt. Inclusion of quantum limited noise and discrete electron charge are going to be more meaningful than a noiseless, continuous charge solution in a question like this.
Same thing with the exponential solution. Only a Deity can wait an infinite amount of time or distinguish between the solutions. Likewise, you will object and object till the end of time. This is useless.In the end, all you would have is a result that only the Deity could determine is correct.
Ratch
Hi all,
i know practically a cap can be fully charged (to an accuracy we take as 100%) but as the voltage goes up in a cap the current drops equally so even when the cap is 99.9999999999% charged would the current would keep lowering so the cap would never actually reach full charge? or would it eventually reach its max?
Regards
" As long as there is a conduction path, a wire does not have a charge distribution.
It will typically have a surface charge distribution. I attached a pdf which discusses this in a basic way.
As I mentioned above, this is completely irrelevant to this discussion, but since you seem to say something misleading, I just pass this information on for the benefit of others.
So, let's look at it another way, using numbers. I think with numbers we can show how the exponential solution reins in the infinity question very nicely.
Let's take a series RC circuit with R=1 ohm and C=1 F. The time constant is 1 second, which is a fairly long time in terms of typical electrical circuits. Typically, we would say that after 5 seconds, the cap is fully charged for all practical purposes. However, your question requires waiting a little longer. How much longer? ... Let's calculate
If we consider applying a voltage of 1 V, then we expect 1 C of charge to end up on the capacitor eventually, and this is a sizable charge. Now, the electron charge is 1.6e-19 C, so let's calculate how long the exponential should take to get within 1e-20 C of 1 C. This is calculated as minus the logarithm base "e" of 1e-20 which equal 46 seconds.
Ok, think about an answer of 46 time constants which it takes to charge to an order of magnitude less than the charge of an electron. Now, what if we wait 100 time constants? We get something around 4e-44 C of charge which is more than 24 orders of magnitude below the electron charge magnitude. Can you even fathom what 24 orders of magnitude means?
Surely we dont have to wait till infinite time to say the capacitor is charged fully. Even in this extreme case, 46 seconds will do it, and 100 seconds will do it for even the most obstinate critic (Ratch likely excluded). It's more than a practical answer, it's a theoretical one too.
The conductor can be symmetrical and still have a charge distribution. Perhaps you mean symmetrical and straight, but real circuits must eventually curve to form a closed circuit, so there will always be a charge in reality.Thanks for the paper. It looks interesting. I should have qualified my statement to say that as long as the conductor is symmetrical, which a wire is, it should not matter too much what the charge distribution is.
Ratch
I'm not really sure what you are saying here.steveB,
Well, let's see. How much voltage does a difference of one electron make? v = q/C = 1.6E-19/1.0 = 1.9E-19 volts below 1 volt. How long does it take to reach that voltage? e^x = 1.6E-19 ---> x = 43.2791 seconds. So what does that prove and where do we go from here?
Ratch
I think it is a reasonable way to look at it too, but keep in mind I was just reiterating what nyaknyan was saying.So i think your explanation best fit the case of the cap charging through a resistance from a voltage source and if it ever gets fully charged, and i think it would be interesting to look into it further too.
