Can I swicth a U1 555 timer with a TLC 555 timer?
BringMeEs&KsM897
I have a schematic for a timer circuit I have everything I need
exept a U1 555 timer but I do have a TLC 555 timer can I switch
the U1 555 timer for the TLC 555 timer?
The timing will be the same, but the output source/sink is reduced.
Please post the circuit.?
That's a link to a file on your hard drive, which we can't see. You need to either:
1. Use the "Go Advanced" button, then click "Manage Attachments" in the message editor to attach the picture (as a clickable thumbnail) to your post, or
2. Create an album ("My Account"--> "My Albums"), upload the picture to an album from your hard drive, then paste a link to the picture (on this site, not your hard drive) into your post.
Oh sorry.
Whats the output pin#3 going to drive.?
On your schematic, U1 is the '555' it's not a special kind. See you have R1, R2 and R3? Which are all resistors. If there were more than one 'chip' they would be named U2, U3 etc. .
Has anybody seen a 3V/1k ohm relay coil that uses only 3mA?? It might use 30mA.
With a 5V supply, a TLC555 typically sinks 20mA with a voltage loss of 1.2V.
They are available in 3v and 5v versions with high resistance coils.
  • 101.pdf
The TLC555 will work OK at 3V, to suit your relay.
Be sure to add a diode across the relay coil to protect the 555 from the relays back EMF, do you know how to do that.?
In addition, you should remember that a TLC555 is a CMOS device and can be destroyed with stray static. I have killed a few myself by accidentaly touching them while not protected. A more robust 555 timer would be better.
