Can the low bits of PORTB be used with LCD
The basic compiler gives error LCD_CHARS not defined. I added define LCD_CHARS = 16
Check in the simulator: after Hseropen 9600, TRISB b1 and b2 should be 1
You can make these already in TRISB settings, but Hseropen should define them correctly.
If they are ok, maybe you have a short in your circuit.
That code is no use to me, I don't even know what it is - although I presume it's some version of BASIC?.
Hi N,
It was written in Oshonsoft Basic. Can you read this ok:
; Compiled with: PIC Simulator IDE v7.27
; Microcontroller model: PIC16F648A
; Clock frequency: 4.0MHz
   R0L EQU 0x020
   R0H EQU 0x021
   R3L EQU 0x026
   R3H EQU 0x027
   R4L EQU 0x028
   R4H EQU 0x029
   R0HL EQU 0x020
   R3HL EQU 0x026
   R4HL EQU 0x028
   ARRARG_0 EQU 0x022
;  The address of 'str1' (array 70) (byte) (global) is 0x02B
;  The address of 'char' (byte) (global) is 0x024
;  The address of 'rxi' (byte) (global) is 0x025
;  The address of 'txi' (byte) (global) is 0x023
;  The address of 'ix' (byte) (global) is 0x02A
;  The address of 'button' (bit) (global) is 0x005,4
;  The address of 'led' (bit) (global) is 0x005,1
   ORG 0x0000
   BCF PCLATH,4
   BCF PCLATH,3
   GOTO L0006
   ORG 0x0004
   RETFIE
; User code start
L0006:
; 1: 'PIC 16F648A 4MHz INT NMEA LCD 240316 0900
; 2: Define CONFIG = 0x3f70
; 3: Define CLOCK_FREQUENCY = 4
; 4: AllDigital
   MOVLW 0x07
   MOVWF CMCON
; 5: Define SIMULATION_WAITMS_VALUE = 1  'SIMULATION ONLY
; 6: Define LCD_LINES = 2
; 7: Define LCD_BITS = 4  'allowed values are 4 and 8 - the number of data interface lines
; 8: Define LCD_DREG = PORTB
; 9: Define LCD_DBIT = 4  '0 or 4 for 4-bit interface, ignored for 8-bit interface
; 10: Define LCD_RSREG = PORTA
; 11: Define LCD_RSBIT = 2
; 12: Define LCD_EREG = PORTA
; 13: Define LCD_EBIT = 3
; 14: Define LCD_RWREG = 0  'set to 0 if not used, 0 is default
; 15: Define LCD_RWBIT = 0  'set to 0 if not used, 0 is default
; 16: Define LCD_COMMANDUS = 5000  'delay after LCDCMDOUT, default value is 5000
; 17: Define LCD_DATAUS = 100  'delay after LCDOUT, default value is 100
; 18: Define LCD_INITMS = 100  'delay used by LCDINIT, default value is 100
; 19: 'PORT A
; 20: 'TRISA = %00000000
; 21: TRISA.0 = 0  'Pin 17
   BSF STATUS,RP0
   BCF TRISA,0
; 22: TRISA.1 = 0  'Pin 18 as LED
   BCF TRISA,1
; 23: TRISA.2 = 0  'Pin 1 as LCD RS
   BCF TRISA,2
; 24: TRISA.3 = 0  'pin 2 as LCD E
   BCF TRISA,3
; 25: TRISA.4 = 1  'Pin 3 as Button
   BSF TRISA,4
; 26: TRISA.5 = 0  'Pin 4 as R/W
   BCF TRISA,5
; 27: TRISA.6 = 0  'Pin 15
   BCF TRISA,6
; 28: TRISA.7 = 0  'Pin 16
   BCF TRISA,7
; 29: 'PORT B
; 30: 'TRISB = %00001010
; 31: TRISB.0 = 0  'pin 6
   BCF TRISB,0
; 32: TRISB.1 = 1  'pin 7 as RX GPS IN
   BSF TRISB,1
; 33: TRISB.2 = 0  'pin 8 as TX out
   BCF TRISB,2
; 34: TRISB.3 = 0  'pin 9
   BCF TRISB,3
; 35: TRISB.4 = 0  'pin 10 as lcd data 4
   BCF TRISB,4
; 36: TRISB.5 = 0  'pin 11 as lcd data 4
   BCF TRISB,5
; 37: TRISB.6 = 0  'pin 12 as lcd data 4
   BCF TRISB,6
; 38: TRISB.7 = 0  'pin 13 as lcd data 4
   BCF TRISB,7
   BCF STATUS,RP0
; 39: PORTB = 0xff
   MOVLW 0xFF
   MOVWF PORTB
; 40: WaitMs 1000
   MOVLW 0x62
   MOVWF R4L
   MOVLW 0x00
   MOVWF R4H
   CALL DL02
; 41: PORTB = 0x00
   CLRF PORTB
; 42: WaitMs 1000
   MOVLW 0x62
   MOVWF R4L
   MOVLW 0x00
   MOVWF R4H
   CALL DL02
; 43: PORTB = 0xff
   MOVLW 0xFF
   MOVWF PORTB
; 44: WaitMs 1000
   MOVLW 0x62
   MOVWF R4L
   MOVLW 0x00
   MOVWF R4H
   CALL DL02
; 45: PORTB = 0x00
   CLRF PORTB
; 46: WaitMs 1000
   MOVLW 0x62
   MOVWF R4L
   MOVLW 0x00
   MOVWF R4H
   CALL DL02
; 47:
; 48: Lcdinit
   BCF PORTA,3
   BCF PORTA,2
   BSF STATUS,RP0
   BCF TRISA,3
   BCF TRISA,2
   MOVLW 0x0F
   ANDWF TRISB,F
   BCF STATUS,RP0
   MOVLW 0x64
   MOVWF R0L
   CLRF R0H
   CALL W001
   MOVLW 0x33
   CALL LC00
   MOVLW 0xE6
   MOVWF R4L
   MOVLW 0x03
   MOVWF R4H
   CALL DL02
   MOVLW 0x33
   CALL LC00
   MOVLW 0x41
   MOVWF R4L
   CALL DL01
   MOVLW 0x33
   CALL LC00
   MOVLW 0x41
   MOVWF R4L
   CALL DL01
   MOVLW 0x22
   CALL LC00
   MOVLW 0x41
   MOVWF R4L
   CALL DL01
   MOVLW 0x28
   CALL LC02
   MOVLW 0x0C
   CALL LC02
   MOVLW 0x01
   CALL LC02
; 49: Hseropen 9600
; exact baud rate achieved = 9615.385; bit period = 104µs; baud rate error = .16%
   BSF STATUS,RP0
   MOVLW 0x19
   MOVWF SPBRG
   BSF TRISB,1
   BSF TRISB,2
   MOVLW 0x24
   MOVWF TXSTA
   BCF STATUS,RP0
   MOVLW 0x90
   MOVWF RCSTA
; 50: Dim str1(70) As Byte
; 51: Dim char As Byte
; 52: Dim rxi As Byte
; 53: Dim txi As Byte
; 54: Dim ix As Byte  'NEW
; 55: 'configure Timer 1
; 56: 'T1CON = 0x30  'prescaler
; 57: 'T1CON.T1OSCEN = 1  'oscilator enabled
; 58: 'T1CON.TMR1CS = 0  'synCharonise with oscilator
; 59: 'T1CON.TMR1ON = 1  'enable timer 1
; 60: 'TMR1H = 0x0b  'high byte of countvalue
; 61: 'TMR1L = 0xdc  'low byte of countvalue
; 62: 'INTCON.GIE = 1
; 63: 'INTCON.PEIE = 1
; 64: 'PIE1.TMR1IE = 1
; 65: 'PIR1.TMR1IF = 0
; 66: Symbol button = PORTA.4  'Push for TIME
; 67: Symbol led = PORTA.1
; 68: Lcdcmdout LcdClear
   MOVLW 0x01
   CALL LC02
; 69: Lcdcmdout LcdLine1Home
   MOVLW 0x80
   CALL LC02
; 70: Lcdout "READY1  READY1"
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x31
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x31
   CALL LC01
; 71: Lcdcmdout LcdLine2Home
   MOVLW 0xC0
   CALL LC02
; 72: Lcdout "READY2  READY2"
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x32
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x32
   CALL LC01
; 73: get_neo:
L0001:
; 74: If RCSTA.OERR = 1 Then  'if over run error then flush RXD buffer
   BTFSS 0x018,1
   GOTO L0007
; 75: RCSTA.CREN = 0
   BCF RCSTA,4
; 76: RCSTA.CREN = 1
   BSF RCSTA,4
; 77: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 78: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 79: PIR1.RCIF = 0
   BCF PIR1,5
; 80: Endif
L0007:
; 81: sync1:  'wait for a $ start of string
L0002:
; 82: If PIR1.RCIF = 0 Then Goto sync1
   BTFSC 0x00C,5
   GOTO L0008
   GOTO L0002
L0008:
; 83: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 84: If char <> 0x24 Then Goto sync1  '$'
   MOVF 0x024,W
   SUBLW 0x24
   BTFSC STATUS,Z
   GOTO L0009
   GOTO L0002
L0009:
; 85: str1(1) = char
   MOVF 0x024,W
   MOVWF 0x02C
; 86: rxi = 2
   MOVLW 0x02
   MOVWF 0x025
; 87: getmsg:  'read and save GPGGA msg
L0003:
; 88: If PIR1.RCIF = 0 Then Goto getmsg
   BTFSC 0x00C,5
   GOTO L0010
   GOTO L0003
L0010:
; 89: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 90: str1(rxi) = char
   BCF STATUS,IRP
   MOVF 0x025,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF 0x024,W
   MOVWF INDF
; 91: rxi = rxi + 1
   MOVF 0x025,W
   ADDLW 0x01
   MOVWF 0x025
; 92: If rxi > 80 Then Goto get_neo  'msg bfr over run
   MOVF 0x025,W
   SUBLW 0x50
   BTFSC STATUS,C
   GOTO L0011
   GOTO L0001
L0011:
; 93: If char = 0x3f Then Goto eomsg  '(0x3f = ?)SIM>>>>>>>>>>>>>>>>>>>>>>>>>>>
   MOVF 0x024,W
   SUBLW 0x3F
   BTFSS STATUS,Z
   GOTO L0012
   GOTO L0004
L0012:
; 94: 'If char = 0x0a Then Goto eomsg  '(0x0a = LF)CIRCUIT>>>>>>>>>>>>>>>>>>>>>>>>
; 95: Goto getmsg
   GOTO L0003
; 96: If rxi < 60 Then  'invalid msg
   MOVLW 0x3C
   SUBWF 0x025,W
   BTFSC STATUS,C
   GOTO L0013
; 97: Goto get_neo
   GOTO L0001
; 98: Endif
L0013:
; 99: eomsg:
L0004:
; 100: If char = 0x3f Then  'SIM 0x3f='?' >>>>>>>>>>>>>>>>>>>.
   MOVF 0x024,W
   SUBLW 0x3F
   BTFSS STATUS,Z
   GOTO L0014
; 101: 'If char = 0x0a Then  'CIRCUIT 0x0a='LF'>>>>>>>>>>>>>>>>>>>.
; 102: If str1(5) = 0x47 Then  'G'>>>>>>>>>>>>>>>>>>>>>>>>>>>>
   MOVF 0x030,W
   SUBLW 0x47
   BTFSS STATUS,Z
   GOTO L0015
; 103: If button = 0 Then Goto time
   BTFSC 0x005,4
   GOTO L0016
   GOTO L0005
L0016:
; 104: Lcdcmdout LcdClear
   MOVLW 0x01
   CALL LC02
; 105: Lcdcmdout LcdLine1Home
   MOVLW 0x80
   CALL LC02
; 106: Lcdout "LAT  "
   MOVLW 0x4C
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x54
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
; 107: For txi = 18 To 28  'LAT
   MOVLW 0x12
   MOVWF 0x023
L0017:
   MOVF 0x023,W
   SUBLW 0x1C
   BTFSS STATUS,C
   GOTO L0018
; 108: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 109: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0017
L0018:
; 110: Lcdcmdout LcdLine2Home
   MOVLW 0xC0
   CALL LC02
; 111: Lcdout "LON "
   MOVLW 0x4C
   CALL LC01
   MOVLW 0x4F
   CALL LC01
   MOVLW 0x4E
   CALL LC01
   MOVLW 0x20
   CALL LC01
; 112: For txi = 31 To 42  'LON
   MOVLW 0x1F
   MOVWF 0x023
L0019:
   MOVF 0x023,W
   SUBLW 0x2A
   BTFSS STATUS,C
   GOTO L0020
; 113: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 114: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0019
L0020:
; 115: For ix = 1 To 72
   MOVLW 0x01
   MOVWF 0x02A
L0021:
   MOVF 0x02A,W
   SUBLW 0x48
   BTFSS STATUS,C
   GOTO L0022
; 116: Hserout str1(ix)  'show msg
   BCF STATUS,IRP
   MOVF 0x02A,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL HS01
; 117: If str1(txi) = 0x0a Then Goto get_neo  'eomsg LF
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   SUBLW 0x0A
   BTFSS STATUS,Z
   GOTO L0023
   GOTO L0001
L0023:
; 118: Next ix
   MOVLW 0x01
   ADDWF 0x02A,F
   BTFSS STATUS,C
   GOTO L0021
L0022:
; 119: Endif
L0015:
; 120: Goto get_neo
   GOTO L0001
; 121: time:
L0005:
; 122: Lcdcmdout LcdClear
   MOVLW 0x01
   CALL LC02
; 123: Lcdcmdout LcdLine1Home
   MOVLW 0x80
   CALL LC02
; 124: For txi = 8 To 15  'TIME
   MOVLW 0x08
   MOVWF 0x023
L0024:
   MOVF 0x023,W
   SUBLW 0x0F
   BTFSS STATUS,C
   GOTO L0025
; 125: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 126: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0024
L0025:
; 127: Lcdcmdout LcdLine2Home
   MOVLW 0xC0
   CALL LC02
; 128: For txi = 53 To 59  'ALT
   MOVLW 0x35
   MOVWF 0x023
L0026:
   MOVF 0x023,W
   SUBLW 0x3B
   BTFSS STATUS,C
   GOTO L0027
; 129: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 130: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0026
L0027:
; 131: Endif
L0014:
; 132: Goto get_neo
   GOTO L0001
; 133: End
L0028:   GOTO L0028
; 134: 'On Interrupt  'every 0,1 second>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
; 135: 'Save System
; 136: 'PIR1.TMR1IF = 0
; 137: 'intrcnt = intrcnt + 1
; 138: 'If intrcnt = 5 Then  '= 0.5 second
; 139: 'intrcnt = 0
; 140: 'TMR1H = 0x0b  'load new values to counter
; 141: 'TMR1L = 0xdc  'load new values to counter
; 142: 'Endif
; 143: 'Resume
; 144:
; End of user code
L0029:   GOTO L0029
; Delay Routine Byte
; minimal routine execution time: 8µs
; routine execution time step: 3µs
; maximal routine execution time: 770µs
DL01:
   DECFSZ R4L,F
   GOTO DL01
   RETURN
; Delay Routine Word
; minimal routine execution time: 15µs
; routine execution time step: 10µs
; maximal routine execution time: 655365µs
DL02:
   MOVLW 0x01
   SUBWF R4L,F
   CLRW
   BTFSS STATUS,C
   ADDLW 0x01
   SUBWF R4H,F
   BTFSS STATUS,C
   RETURN
   GOTO DL02
; Waitms Routine
W001:   MOVLW 0x01
   SUBWF R0L,F
   CLRW
   BTFSS STATUS,C
   ADDLW 0x01
   SUBWF R0H,F
   BTFSS STATUS,C
   RETURN
   MOVLW 0x61
   MOVWF R4L
   MOVLW 0x00
   MOVWF R4H
   CALL DL02
   GOTO W001
; Lcdout Routine
LC01:
   MOVWF R3L
   BSF PORTA,2
   MOVF PORTB,W
   MOVWF R3H
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVF PORTB,W
   MOVWF R3H
   SWAPF R3L,F
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVLW 0x1F
   MOVWF R4L
   CALL DL01
   RETURN
LCX6:
   MOVLW 0x0F
   ANDWF R3H,F
   MOVF R3L,W
   ANDLW 0xF0
   IORWF R3H,W
   RETURN
LCX1:
   BSF PORTA,3
   NOP
   BCF PORTA,3
   NOP
   RETURN
; Lcdinit Routine
LC00:
   BCF PORTA,2
   MOVWF R3L
   MOVF PORTB,W
   MOVWF R3H
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   RETURN
; Lcdcmdout Routine
LC02:
   MOVWF R3L
   BCF PORTA,2
   MOVF PORTB,W
   MOVWF R3H
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVF PORTB,W
   MOVWF R3H
   SWAPF R3L,F
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVLW 0xF2
   MOVWF R4L
   MOVLW 0x01
   MOVWF R4H
   CALL DL02
   RETURN
; Hardware Serial Communication Routines
HS01:
   BTFSC PIR1,TXIF
   GOTO HS02
   GOTO HS01
HS02:   MOVWF TXREG
   RETURN
HS10:
   BTFSC PIR1,RCIF
   GOTO HS11
   GOTO HS10
HS11:   MOVF RCREG,W
   RETURN
; Configuration settings
   ORG 0x2007
   DW 0x3F70
; End of listing
   END
C
MOD edit*** I wish you would use code tags...
EDIT: Who wrote the line above? If you mean indent between IF and ENDIF, I try to in Basic, but I can't in ASM.
As mentioned before, at the beginning of the program I added PORTB ON/OFF so I can see if the PIC including PIN 8 TX is working. I changed it to ON/OFF/ON, leaving PORTB ON, and now it is working, and sending data out of the TX pin.
Thanks to everyone, who helped me.
Camerart.
This .asm listing is from different program than msg #7 ?
The config words are 0x3f50 in msg#7 and 0x3f70 in .asm file.
The problem is probably not in this, but could you show the Basic file of the program you are using.
Edit: ok, did not notice you got it fixed.
Hi J,
Yes, I must have tried 0x3f70 then forgot to switch back.
I'm still working on it. It does now send to TX and computer terminal, and I'm now trying to get it to show sentences lined up $ below $ etc.
Also the button has stopped working. The button switches the LCD to show either LON and LAT or TIME and ALT.
If you're still interested here's the code and ASM.
C.
  • PIC 16F648A 4MHz INT NMEA LCD 250316 1130.txt
  • PIC 16F648A 4MHz INT NMEA LCD 250316 1130.asm
Me
Using the above tags with posted code makes it MUCH easier to read!!
Me
Hi I,
Is this ok?
C.
'PIC 16F648A 4MHz INT NMEA LCD 250316 1130
Define CONFIG = 0x3f50
AllDigital
'Define SIMULATION_WAITMS_VALUE = 1  'SIMULATION ONLY
Define LCD_CHARS = 16  '>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>.
Define LCD_EBIT = 3
Define LCD_RWREG = PORTA  'set to 0 if not used, 0 is default
Define LCD_RWBIT = 5  'set to 0 if not used, 0 is default
CMCON = 7  '>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
'OPTION_REG.7 = 0  'Enable Pull-Up's (Not work PORTB = 0xff instead)
Hseropen 9600  'Moved from below TRIS>>>>>>>>>>>>>>>>>>>>>>>>>.
'PORT A
'TRISA = %00000000
TRISA.0 = 0  'Pin 17
TRISA.6 = 0  'Pin 15
TRISA.7 = 0  'Pin 16
'PORT B
'TRISB = %00001010
TRISB.0 = 0  'pin 6
TRISB.2 = 1  'pin 8 as TX out (Set as in)>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>.
TRISB.3 = 0  'pin 9
PORTB = 0xff  '(See above pull ups) Switches PORTB inc TX on >>>>>>>>>>>>>>>>>>>>>>>
Lcdinit
Dim char As Byte
Dim rxi As Byte
Dim txi As Byte
Dim ix As Byte  'NEW
Lcdcmdout LcdClear
get_neo:
RCSTA.CREN = 0
RCSTA.CREN = 1
char = RCREG
char = RCREG
PIR1.RCIF = 0
Endif
char = RCREG
str1(1) = char
rxi = 2
char = RCREG
str1(rxi) = char
rxi = rxi + 1
'If char = 0x3f Then Goto eomsg  '(0x3f = ?)SIM>>>>>>>>>>>>>>>>>>>>>>>>>>>
Goto getmsg
   Goto get_neo
Endif
eomsg:
'If char = 0x3f Then  'SIM 0x3f='?' >>>>>>>>>>>>>>>>>>>.
     Lcdcmdout LcdClear
     Lcdout "LAT  "
       Lcdout str1(txi)
     Next txi
     Lcdout "LON "
       Lcdout str1(txi)
     Next txi
For ix = 1 To 72
   Hserout str1(ix)  'show msg>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Next ix
Hserout 0x0a
   'If str1(txi) = 0x3f Then Goto get_neo  'eomsg ?
'Next ix
Endif
Goto get_neo
time:
     Lcdcmdout LcdClear
       Lcdout str1(txi)
     Next txi
       Lcdout str1(txi)
     Next txi
   Endif
Goto get_neo
End
'On Interrupt
'Save System
'PIR1.RCIF = 0
'Hserin char
'If char = 0x0a Then  'test for string start
   'rxi = 0
'Endif
'str1(rxi) = char
'rxi = rxi + 1
'If char = 0x0a Then  'test for temporary LF code
   'For txi = 0 To rxi
   'Hserout str1(txi)
   'If str1(txi) = "," Then Hserout CrLf  'a demo on how to break the string into chunks.!
   'Next txi
'Endif
'Resume
Final programs:)
I hope you don't have to edit theses:arghh:
C.
   R0L EQU 0x020
   R0H EQU 0x021
   R3L EQU 0x026
   R3H EQU 0x027
   R4L EQU 0x028
   R4H EQU 0x029
   R0HL EQU 0x020
   R3HL EQU 0x026
   R4HL EQU 0x028
   ARRARG_0 EQU 0x022
   ORG 0x0000
   BCF PCLATH,4
   BCF PCLATH,3
   GOTO L0006
   ORG 0x0004
   RETFIE
; User code start
L0006:
; 1: 'PIC 16F648A 4MHz INT NMEA LCD 260316 0900
; 2: Define CONFIG = 0x3f50
; 4: AllDigital
   MOVLW 0x07
   MOVWF CMCON
; 5: 'Define SIMULATION_WAITMS_VALUE = 1  'SIMULATION ONLY
; 6: Define LCD_CHARS = 16
; 7: Define LCD_LINES = 2
; 8: Define LCD_BITS = 4  'allowed values are 4 and 8 - the number of data interface lines
; 9: Define LCD_DREG = PORTB
; 10: Define LCD_DBIT = 4  '0 or 4 for 4-bit interface, ignored for 8-bit interface
; 11: Define LCD_RSREG = PORTA
; 12: Define LCD_RSBIT = 2
; 13: Define LCD_EREG = PORTA
; 14: Define LCD_EBIT = 3
; 15: Define LCD_RWREG = PORTA  'set to 0 if not used, 0 is default
; 16: Define LCD_RWBIT = 5  'set to 0 if not used, 0 is default
; 17: Define LCD_COMMANDUS = 5000  'delay after LCDCMDOUT, default value is 5000
; 18: Define LCD_DATAUS = 100  'delay after LCDOUT, default value is 100
; 19: Define LCD_INITMS = 100  'delay used by LCDINIT, default value is 100
; 20: CMCON = 7
   MOVLW 0x07
   MOVWF CMCON
; 21: Hseropen 9600
   BSF STATUS,RP0
   MOVLW 0x19
   MOVWF SPBRG
   BSF TRISB,1
   BSF TRISB,2
   MOVLW 0x24
   MOVWF TXSTA
   BCF STATUS,RP0
   MOVLW 0x90
   MOVWF RCSTA
; 22: 'PORT A
; 23: TRISA.0 = 0  'Pin 17
   BSF STATUS,RP0
   BCF TRISA,0
; 24: TRISA.1 = 0  'Pin 18 as LED
   BCF TRISA,1
; 25: TRISA.2 = 0  'Pin 1 as LCD RS
   BCF TRISA,2
; 26: TRISA.3 = 0  'pin 2 as LCD E
   BCF TRISA,3
; 27: TRISA.4 = 1  'Pin 3 as Button
   BSF TRISA,4
; 28: TRISA.5 = 0  'Pin 4 as R/W
   BCF TRISA,5
; 29: TRISA.6 = 0  'Pin 15
   BCF TRISA,6
; 30: TRISA.7 = 0  'Pin 16
   BCF TRISA,7
; 31: 'PORT B
; 32: TRISB.0 = 0  'pin 6
   BCF TRISB,0
; 33: TRISB.1 = 1  'pin 7 as RX GPS IN
   BSF TRISB,1
; 34: TRISB.2 = 1  'pin 8 as TX out (Set as in)
   BSF TRISB,2
; 35: TRISB.3 = 0  'pin 9
   BCF TRISB,3
; 36: TRISB.4 = 0  'pin 10 as lcd data 4
   BCF TRISB,4
; 37: TRISB.5 = 0  'pin 11 as lcd data 4
   BCF TRISB,5
; 38: TRISB.6 = 0  'pin 12 as lcd data 4
   BCF TRISB,6
; 39: TRISB.7 = 0  'pin 13 as lcd data 4
   BCF TRISB,7
   BCF STATUS,RP0
; 40: PORTB = 0xff
   MOVLW 0xFF
   MOVWF PORTB
; 41: Lcdinit
   BCF PORTA,3
   BCF PORTA,2
   BCF PORTA,5
   BSF STATUS,RP0
   BCF TRISA,3
   BCF TRISA,2
   BCF TRISA,5
   MOVLW 0x0F
   ANDWF TRISB,F
   BCF STATUS,RP0
   MOVLW 0x64
   MOVWF R0L
   CLRF R0H
   CALL W001
   MOVLW 0x33
   CALL LC00
   MOVLW 0xE6
   MOVWF R4L
   MOVLW 0x03
   MOVWF R4H
   CALL DL02
   MOVLW 0x33
   CALL LC00
   MOVLW 0x41
   MOVWF R4L
   CALL DL01
   MOVLW 0x33
   CALL LC00
   MOVLW 0x41
   MOVWF R4L
   CALL DL01
   MOVLW 0x22
   CALL LC00
   MOVLW 0x41
   MOVWF R4L
   CALL DL01
   MOVLW 0x28
   CALL LC02
   MOVLW 0x0C
   CALL LC02
   MOVLW 0x01
   CALL LC02
; 42: Dim str1(70) As Byte
; 43: Dim char As Byte
; 44: Dim rxi As Byte
; 45: Dim txi As Byte
; 46: Dim ix As Byte  'NEW
; 47: Symbol button = PORTA.4  'Push for TIME
; 48: Symbol led = PORTA.1
; 49: Lcdcmdout LcdClear
   MOVLW 0x01
   CALL LC02
; 50: Lcdcmdout LcdLine1Home
   MOVLW 0x80
   CALL LC02
; 51: Lcdout "READY1  READY1"
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x31
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x31
   CALL LC01
; 52: Lcdcmdout LcdLine2Home
   MOVLW 0xC0
   CALL LC02
; 53: Lcdout "READY2  READY2"
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x32
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x52
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x44
   CALL LC01
   MOVLW 0x59
   CALL LC01
   MOVLW 0x32
   CALL LC01
; 54: get_neo:
L0001:
; 55: If RCSTA.OERR = 1 Then  'if over run error then flush RXD buffer
   BTFSS 0x018,1
   GOTO L0007
; 56: RCSTA.CREN = 0
   BCF RCSTA,4
; 57: RCSTA.CREN = 1
   BSF RCSTA,4
; 58: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 59: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 60: PIR1.RCIF = 0
   BCF PIR1,5
; 61: Endif
L0007:
; 62: sync1:  'wait for a $ start of string
L0002:
; 63: If PIR1.RCIF = 0 Then Goto sync1
   BTFSC 0x00C,5
   GOTO L0008
   GOTO L0002
L0008:
; 64: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 65: If char <> 0x24 Then Goto sync1  '$'
   MOVF 0x024,W
   SUBLW 0x24
   BTFSC STATUS,Z
   GOTO L0009
   GOTO L0002
L0009:
; 66: str1(1) = char
   MOVF 0x024,W
   MOVWF 0x02C
; 67: rxi = 2
   MOVLW 0x02
   MOVWF 0x025
; 68: getmsg:  'read and save GPGGA msg
L0003:
; 69: If PIR1.RCIF = 0 Then Goto getmsg
   BTFSC 0x00C,5
   GOTO L0010
   GOTO L0003
L0010:
; 70: char = RCREG
   MOVF RCREG,W
   MOVWF 0x024
; 71: str1(rxi) = char
   BCF STATUS,IRP
   MOVF 0x025,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF 0x024,W
   MOVWF INDF
; 72: rxi = rxi + 1
   MOVF 0x025,W
   ADDLW 0x01
   MOVWF 0x025
; 73: If rxi > 80 Then Goto get_neo  'msg bfr over run
   MOVF 0x025,W
   SUBLW 0x50
   BTFSC STATUS,C
   GOTO L0011
   GOTO L0001
L0011:
; 74: If char = 0x0a Then Goto eomsg
   MOVF 0x024,W
   SUBLW 0x0A
   BTFSS STATUS,Z
   GOTO L0012
   GOTO L0004
L0012:
; 75: Goto getmsg
   GOTO L0003
; 76: If rxi < 60 Then  'invalid msg
   MOVLW 0x3C
   SUBWF 0x025,W
   BTFSC STATUS,C
   GOTO L0013
; 77: Goto get_neo
   GOTO L0001
; 78: Endif
L0013:
; 79: eomsg:
L0004:
; 80: If str1(5) = 0x47 Then  'G'
   MOVF 0x030,W
   SUBLW 0x47
   BTFSS STATUS,Z
   GOTO L0014
; 81: If button = 0 Then Goto time
   BTFSC 0x005,4
   GOTO L0015
   GOTO L0005
L0015:
; 82: Lcdcmdout LcdClear
   MOVLW 0x01
   CALL LC02
; 83: Lcdcmdout LcdLine1Home
   MOVLW 0x80
   CALL LC02
; 84: Lcdout "LA  "
   MOVLW 0x4C
   CALL LC01
   MOVLW 0x41
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
; 85: For txi = 18 To 29  'LAT
   MOVLW 0x12
   MOVWF 0x023
L0016:
   MOVF 0x023,W
   SUBLW 0x1D
   BTFSS STATUS,C
   GOTO L0017
; 86: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 87: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0016
L0017:
; 88: Lcdcmdout LcdLine2Home
   MOVLW 0xC0
   CALL LC02
; 89: Lcdout "LO "
   MOVLW 0x4C
   CALL LC01
   MOVLW 0x4F
   CALL LC01
   MOVLW 0x20
   CALL LC01
; 90: For txi = 31 To 43  'LON
   MOVLW 0x1F
   MOVWF 0x023
L0018:
   MOVF 0x023,W
   SUBLW 0x2B
   BTFSS STATUS,C
   GOTO L0019
; 91: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 92: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0018
L0019:
; 93: For ix = 1 To 72
   MOVLW 0x01
   MOVWF 0x02A
L0020:
   MOVF 0x02A,W
   SUBLW 0x48
   BTFSS STATUS,C
   GOTO L0021
; 94: Hserout str1(ix)  'show msg
   BCF STATUS,IRP
   MOVF 0x02A,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL HS01
; 95: Next ix
   MOVLW 0x01
   ADDWF 0x02A,F
   BTFSS STATUS,C
   GOTO L0020
L0021:
; 96: Hserout 0x0d, 0x0a
   MOVLW 0x0D
   CALL HS01
   MOVLW 0x0A
   CALL HS01
; 97: Endif
L0014:
; 98: Goto get_neo
   GOTO L0001
; 99: time:
L0005:
; 100: Lcdcmdout LcdClear
   MOVLW 0x01
   CALL LC02
; 101: Lcdcmdout LcdLine1Home
   MOVLW 0x80
   CALL LC02
; 102: Lcdout "TIME "
   MOVLW 0x54
   CALL LC01
   MOVLW 0x49
   CALL LC01
   MOVLW 0x4D
   CALL LC01
   MOVLW 0x45
   CALL LC01
   MOVLW 0x20
   CALL LC01
; 103: For txi = 8 To 13  'TIME
   MOVLW 0x08
   MOVWF 0x023
L0022:
   MOVF 0x023,W
   SUBLW 0x0D
   BTFSS STATUS,C
   GOTO L0023
; 104: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 105: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0022
L0023:
; 106: Lcdcmdout LcdLine2Home
   MOVLW 0xC0
   CALL LC02
; 107: Lcdout "ALT  "
   MOVLW 0x41
   CALL LC01
   MOVLW 0x4C
   CALL LC01
   MOVLW 0x54
   CALL LC01
   MOVLW 0x20
   CALL LC01
   MOVLW 0x20
   CALL LC01
; 108: For txi = 55 To 61  'ALT
   MOVLW 0x37
   MOVWF 0x023
L0024:
   MOVF 0x023,W
   SUBLW 0x3D
   BTFSS STATUS,C
   GOTO L0025
; 109: Lcdout str1(txi)
   BCF STATUS,IRP
   MOVF 0x023,W
   ADDLW 0x2B
   MOVWF FSR
   MOVF INDF,W
   CALL LC01
; 110: Next txi
   MOVLW 0x01
   ADDWF 0x023,F
   BTFSS STATUS,C
   GOTO L0024
L0025:
; 111: Goto get_neo
   GOTO L0001
; 112: End
L0026:   GOTO L0026
; End of user code
L0027:   GOTO L0027
DL01:
   DECFSZ R4L,F
   GOTO DL01
   RETURN
DL02:
   MOVLW 0x01
   SUBWF R4L,F
   CLRW
   BTFSS STATUS,C
   ADDLW 0x01
   SUBWF R4H,F
   BTFSS STATUS,C
   RETURN
   GOTO DL02
; Waitms Routine
W001:   MOVLW 0x01
   SUBWF R0L,F
   CLRW
   BTFSS STATUS,C
   ADDLW 0x01
   SUBWF R0H,F
   BTFSS STATUS,C
   RETURN
   MOVLW 0x61
   MOVWF R4L
   MOVLW 0x00
   MOVWF R4H
   CALL DL02
   GOTO W001
; Lcdout Routine
LC01:
   MOVWF R3L
   BSF PORTA,2
   BCF PORTA,5
   MOVF PORTB,W
   MOVWF R3H
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVF PORTB,W
   MOVWF R3H
   SWAPF R3L,F
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVLW 0x1F
   MOVWF R4L
   CALL DL01
   RETURN
LCX6:
   MOVLW 0x0F
   ANDWF R3H,F
   MOVF R3L,W
   ANDLW 0xF0
   IORWF R3H,W
   RETURN
LCX1:
   BSF PORTA,3
   NOP
   BCF PORTA,3
   NOP
   RETURN
; Lcdinit Routine
LC00:
   BCF PORTA,2
   BCF PORTA,5
   MOVWF R3L
   MOVF PORTB,W
   MOVWF R3H
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   RETURN
; Lcdcmdout Routine
LC02:
   MOVWF R3L
   BCF PORTA,2
   BCF PORTA,5
   MOVF PORTB,W
   MOVWF R3H
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVF PORTB,W
   MOVWF R3H
   SWAPF R3L,F
   CALL LCX6
   MOVWF PORTB
   CALL LCX1
   MOVLW 0xF2
   MOVWF R4L
   MOVLW 0x01
   MOVWF R4H
   CALL DL02
   RETURN
HS01:
   BTFSC PIR1,TXIF
   GOTO HS02
   GOTO HS01
HS02:   MOVWF TXREG
   RETURN
HS10:
   BTFSC PIR1,RCIF
   GOTO HS11
   GOTO HS10
HS11:   MOVF RCREG,W
   RETURN
   ORG 0x2007
   DW 0x3F50
; End of listing
   END
AllDigital
Define LCD_EBIT = 3
CMCON = 7
Hseropen 9600
'PORT A
TRISA.0 = 0  'Pin 17
TRISA.6 = 0  'Pin 15
TRISA.7 = 0  'Pin 16
'PORT B
TRISB.0 = 0  'pin 6
TRISB.3 = 0  'pin 9
PORTB = 0xff
Lcdinit
Dim char As Byte
Dim rxi As Byte
Dim txi As Byte
Dim ix As Byte  'NEW
Lcdcmdout LcdClear
get_neo:
RCSTA.CREN = 0
RCSTA.CREN = 1
char = RCREG
char = RCREG
PIR1.RCIF = 0
Endif
char = RCREG
str1(1) = char
rxi = 2
char = RCREG
str1(rxi) = char
rxi = rxi + 1
Goto getmsg
   Goto get_neo
Endif
eomsg:
   Lcdcmdout LcdClear
   Lcdout "LA  "
     Lcdout str1(txi)
   Next txi
   Lcdout "LO "
     Lcdout str1(txi)
   Next txi
   For ix = 1 To 72
   Next ix
   Hserout 0x0d, 0x0a
Endif
Goto get_neo
time:
   Lcdcmdout LcdClear
   Lcdout "TIME "
     Lcdout str1(txi)
   Next txi
   Lcdout "ALT  "
     Lcdout str1(txi)
   Next txi
Goto get_neo
End
