The first half of this thread was fascinating to me ... I keep coming back looking/waiting for more information ... Little Ghostman ???
I've read a lot of other threads and now understand microbial fuel cells (well at least I know what they are now) ... but am interested in some real world stuff ... something that I might be able to apply on my property.
I understand you have talked about two different things ... one being some sort of "earth battery" ... and then a more conventional methane generation system to run traditional generators etc.
I'm interested to learn of this Carbon Neutral process, sounds fascinating ... but the bio digestor and generator idea is something I could get my teeth into.
We are on a few acres ... grass ... sheep ... people ... and have plenty of shed space to play with.
Even IBC containers are plentiful around here.
And who would be happy with 30% efficiency if they knew 90% was attainable. Can you point me to some of this latest information please?
Thanks.
Carbon neutral is so not your thing...trust me on this. Go bio digester and alter a generator to use the gas to run a generator, this is about modern building techniques and rules a ****, if you can skip those and dont care about your carbon footprint, then seriously there are easier ways to make electric!
If you have an acre of land set to grass, and two - three sheep on it, a house of 3-4 people and access to organic material. Then it makes more sense to use a modern (read new) Bio methane system, i am not on about these hopeless bag things being sold, but a 4-6 chamber system.
Normal Bio methane efficiency is only around ~30% tops. New systems are up around 90%, they also crucially run at lower temperatures, and use waste heat from the generator unit to help sustain the biological activity. these systems can run modified Gas generators in the 15KW range, the main problem is tweaking them so you can feed them enough to produce the volume of gas needed. this is why it matters that you make the entire system efficient. If your house is insulated and near modern specs, then you can probably run your entire house off of them.
Thanks.
