roltex_rohit123
I have just rebuild my laptop battery and the cells that i replaced with new ones still hold a good charge. laptop used to give me 20 min backup when i took out the cells. I want to utilise the cells in a backup charger circuit for my cell phone and I-pod. i measured the voltage in the cell charger and it was about 6 volts. i want to use 2 lithium cells in parallel. they give about 4.1-4.2 volts, when charged. how can i proceed for the circuit. I need a higher voltage 6 volts at 300mA. The cells I suppose might be holding about 0.5 amp charge each. I have plenty of these cells for use. i can charge my cell when power is not available and then recharge both cells and backup battery pack when power is available. which IC's and what components can i use?
