characteristics and apps: PIC16F870
This is what I want:
initializate interrupt for RB0/INT
so it will be always runing, when and event is occurred a counterA will be incremented
intializate ADC, I can start/stop the ADC when I want
Initializate timer0
it will run forever, and generates an interrupt every 20ms
if by the ADC I detect 1.25V = (ADRESH=0, ADRESL=256)
and if this event occurs for an equal interval of 300ms then I should turn on a led and increment counterB. then after 1 minute I should turn off the led
if againf by the ADC I detect 1.25V, and it persists for 300mS I should turn on a led, after one minute I should stop the led and increment counterB.
but, if before the second event there haven't been any other event for about 30 minutes then I should clear counterB
how i can gent the 30 minutes, without taking processing time as delays do
with timer1, this is a 16 bit register.
also I want to know if ADC can run without taking processing as delays
If you're already using timer0 to generate interrupts every 20mS, use that same clock - simply increment, or decrement, registers in order to get the time you require. For a 20mS interrupt the first obvious counter is from (or to) 50, to give a count in seconds, from that you count again, from (or to) 60, to give minutes - and so on as long as you need!.
ADC Vs RB0
what happens when i am waiting the ADC to finish and before it occurs and interrupt from RB0 occurs, does the ADC still sample the signal or it stops and then will start again the sampling or it will go through the code.
Re: ADC Vs RB0
The ADC operates seperately from the processor, so it will continue to sample while the interrupt routine is active. When the interrupt routine returns it will find the flag set if the ADC has finished - assuming you're using polling to check for the ADC finishing?.
thanks a lot!
what about if I am not polling the ADC, I mean I will enable this periphereal interrupt and If ADC finish while RB0 interrupt was attended or any other interrupt is generated.
what happens?
I will use the followinf interrupts
TIMER0 every 20ms
RB0/INT, external event
ADC
sardineta said:
thanks a lot!
what happens?
TIMER0 every 20ms
ADC
You should arrange your program to minimise the number of simultaneous interrupts - when an interrupt is called it disables further interrupts, and your interrupt code should enable then again as it exits, when any pending interrupts will be serviced.
I don't claim to be an expert on PIC interrupts, I only use them occasionally - mostly you can avoid using them - from your description so far it looks like you probably only require the 20mS timer interrupt. Most interrupt intensive code you see consists of sitting in endless loops waiting for an interrupt to occur, you may as well carry out polling during this loop instead.
ADC
I have heard that the input impedance to the ADC from the microcontroller should be 2.5K.
what about if I directly connect a potentiometer to handle a voltage level to the ADC input.
what about the input impedance?
this effect is saw when using opamps? or when I should take care of it?
c u
Re: ADC
The main problem is the speed of charging the internal sample and hold capacitor, you may have to wait a substanial time between samples, particularly when switching channels. Although it's been suggested that accuracy can suffer slightly as well - but I've not checked this, from the suggestion accuracy should still be plenty higher than your support components (so I don't see it as a problem!).
If you feed the A2D input from an opamp you won't see the effect, you should do this is you want maximum speed!.
I have 2Kx14 of flash memory (program memory) in the 16F870 uC
I have already compiled my asm code and this process generated a hex file of 2657 bytes.
Does this file fit in the PROGRAM MEMORY?
Another question:
Every variable I need, it should be initializad to zero by software?.
example equ 0x20
movlw 0x00
movwf example
or on power on data memory all bytes are zero.
I would like to know it because if ram is initialized to 0's on power on my code redeuce because I do not do it by software, but it still is above 2400 bytes.
Thanks in advanced
The hex file contains the data as ascii indormation and it also carries address information. This makes the hex file a LOT! larger then the actual code size.
if you want to know how much memory is required you should let the compiler generate a list file, it tells you how much memory is required.
You can also see it when you load the file into your programmer.
example equ 0x20
movlw 0x00
movwf example
It's always best to initialize any variables you use.
To make your code smaller you can use indirect adressing to clear a whole block of memory in a small loop.
it should fit because 1/4 of the hex file or assembled program are zeros.. this equals 1992 14 bit bytes.. so it should fit..
How many zero's are in it doesn't matter
it's a intel hex file (do a google search). The data is stored as ascii wich makes it twice as large as it actually is. It also holds adress information for every 16 bytes of data wich doesn't get transferred.
thanks a lot.
I will change the direct initialization mode by indirect mode
and the file size it makes feel light. (ligerito)
i am well aware of the extra digits in a hex file..
but i was just looking at a 70 byte hex file dos file size...and it had 66 hex digits in it plus two coln's =68 bytes plus the carrage reuurn & line feed , makes 70 bytes.. but it wasnt 132 bytes long ..go figure...
anyway i agree there are 6 bytes per line that dont get programmed into the part..counting the coln...
what i was talking about was 2 bytes of hex file data , can fit into one 14 bit program memory location...so the 2048 program memory of the 16F870 could hold a hex file at least 4096 bytes long ...
Thanks a lot for your comments.
I really appreciate that.
I realized that I have a ommited a register. This is the Configuration Register, some parameters can be very easy deduced but others I really do not know:
I have it in my _CONFIG
_CONFIG (MSB) NC,NC,11 0111 x011 1010 (LSB)
bit 13&12 =4&5 = 11, code protection off
bit 11 = 1, in-circuit debugger disable
bit 10 unimplemented
bit 9 WRT = 1, unprotected program memory may be written to
WHAT YOU RECOMMEND ME in bit 9
bit 8 CPD = 1 code protection OFF
bit 7 LVP = X I do not know what's in here
WHAT YOU RECOMMEND ME in bit 7
bit 6 BOREN = 0 disable
bit 3 PWRTEN = 1 disable
bit 2 WDTEN = 0 disable
bit 1 y 0 Fosc1 y 2 = 10 HS oscillator
I will use a burner called from "solaris digital" model S-103
so I think some control bits depends on it, isn't it?
what you recommend me to do with the configuration words
thanks in advanced
bit 7 LVP: Low Voltage In-Circuit Serial Programming Enable bit
1 = RB3/PGM pin has PGM function, low voltage programming enabled
0 = RB3 is digital I/O, HV on MCLR must be used for programming..
low voltage programming is with the on chip serial port .. i assume that u are using MCLR to program the part so bit 7 is a zero
i am pretty sure that bit 9 has to do with on chip serial programming.. also.. but i am not sure 100 % ...anyone else..??
bit 9 WRT: FLASH Program Memory Write Enable
1 = Unprotected program memory may be written to by EECON control
0 = Unprotected program memory may not be written to by EECON control
the correct initialization of a program should be
org 0x00
goto MAIN ;main program
org 0x04
goto ISR ;interruption service routine
MAIN ;main program begin here
blablabla
ISR ;ISR begin here
blablabla
RETFIE
END
I have seen that some people use org 0x05, does anyone know why?
I have seen it from Nigel's programs and I really do not undestand why ORG 0x00 is sometimes 0x20 for example.
is it really important, for the ISR?
I have my program finished, but when I simulate it in the MPLAB, the TMR0, is not reloaded, does I need to reload it at the end of the ISR before exit? before bcf INTCON T0IF
Where have you seen that? i've never come across code wich used 0x05 as the origin for the ISR.
Take a better look, it's the cblock that starts at 0x20 in Nigel's examples. The cblock is where variables in RAM are declared.
