Charging a battery with a supercap
Oh sorry Diver, I thought you were replying to my post, you're right.
Hey Blueroom,
Could you explain a little more about the ESR point you made, I'm not very savvy on that particular part. From the website the ultracap has an ESR of 19mOhms; is that milli or mega?
Also here is a link to the paper I read...
Thanks!
My general understanding of super capacitors is that they tend to either have a very high ESR or a very high leakage current. I think he was confusing them with the type of super capacitors used as a backup for CMOS memory ICs.
The types of super capacitor used in automotive applications have a very low ESR but tend to have a high leakage current which is even worse in this application because it will flatten the battery.
I suppose you might be able to get low ESR low leakage super capacitors but they would be very expensive.
EDIT:
I notice you've linked an article which you have to pay for.
Have you bought it?
Could you please post a small part of it which would be classed as fair dealing under copyright law?
I'm very skeptical, if there is a way of reducing sulphation then I would think it would be more complicated than just connecting a super capacitor in parallel with the battery.
The supercap in question has a current leakage of 1 mA after 72hours at 25deg c. Check it out here
Maxwell Technologies: Ultracapacitors - BPAK0058-15V
Anyways, thank you all for your constructive criticism; its given me good points to critically analyse; however the topic is to get some help on how to quantify the decisions I have made.
Hero, one of the benefits of being at university is that I get a free Athens login! :D
Back to the calculus!
Anyone know by anychance how much voltage and current a typical brushless dynamo will give off compared to its RPM? I'm assuming it corresponds to its windings?
I think I can understand how this works now, the capacitor can charge and discharge faster, more efficiently and has a longer life than the battery so it takes some of the strain off it.
1mA is quite high for a capacitor, it's probably a good idea to disconnect it when it isn't being used.
Blueroom, I don't plan on having conventional dynamos, just a hub motor which fits into the wheel; so yes this will act as a brake, much like engine braking in a car. Check out the current E-bikes on the market to see! Some incoroprate a freewheel planetary gear system, but this eliminates the possibility of regen =( There are ways around this too of course =)
That is correct hero! Although current leakage shouldnt be too bad considering most people will use their bike twice 5 days a week (commuters). Also, with the circuit design, once the controller is switched off, the capacitor will be isolated (as standard).
