Hi again,
Is that 47 ohm resistor a 10 watt wire wound? Couldnt find that one on the RS site.
That may just take the punishment you intend to give it just barely below what will make it an open circuit
It depends partly on how the device was manufactured, as sometimes to increase production yields the device is 'adjusted' using some sort of grinding which can adversely affect it's joule capability (surge rating). That means one device may work and the other may blow out (cheaper versions would most likely be the adjusted type).
What will be harder to predict would be how long the resistor would last in this kind of application which regularly subjects it to high stress. The high dT/dt might crack the case the first time it is used for example, or later down the road when it looks like it is working just fine.
If you get a chance to pull one apart and check the wire diameter we can estimate the fusing current vs time.
