Clarkdale44
Pretty s
Yeah my meter has two ranges, 200A and 1000A.
Pretty sweet trick... Gladly it works great. Now i can read the current draw even on small appliances. Thanks
Yeah i had a battery that was combobulating and using the discombobulation switch on the charger cleared it right up
Congrats to Clarkdale for success with the second test.
I could not find any good data on the meter except that the frequency response is 50 to 60Hz, which of course means AC.
If you have the 200 amp AC model a trick to get it to read like the 20 amp model is to use a small coil of 10 turns of the wire or if testing AC appliances make up a plug in adapter with a coil with 10 turns of wire and clamp those ten turns all at once. The meter will read approximately 200 amps for a 20 amp real life AC current.
