Actually I just want to compare the resistance between pins of the measured IC with the good IC, from here I will know it is leakage or open.Nigel Goodwin said:What would be the point of measuring the 'resistance' of an IC?.
In any case, the current will only be low, and the voltage probably MUCH less that 5V.
wkyong said:Actually I just want to compare the resistance between pins of the measured IC with the good IC, from here I will know it is leakage or open.
