Kookie
Hi, I am about to make this circuit and I wanted to submit it for scrutiny before I even breadboard it. (The values for "x" have not been determined yet.) Will it work?
Its been a very long time since I did this sort of thing and I'm not sure if I designed it correctly.
The purpose of the circuit is frivolous, so I wont go into that, but basically its replacing an indicator light (plug in LED) with this circuit that will light the LED plus a couple more and turn a motor.
Here are my questions about the circuit:
1) Will it work in theory?
2) I have R1 and LED1 on the emitter side of the transistor in the optoisolator. Is that ok?
3) I want to make the pair of LEDs (LED23) slowly turn off. Dim to off. To do this, I'm thinking C1 can achieve this. Am I correct?
4) Is there a voltage drop of 0.7 between the collector and emitter of the transistors, or is that just between the base and emitter? (Can't remember )
5) I want to design this as small as possible, with as little parts as possible. Here's what I have to put it in: **broken link removed**
Its very cramped, but I should be able to put it all in. Depending on the size of C1, if that will work at all. Would there be a better design?
So, what do you think? I really appreciate your time and expertise with any help and input you can give me. Thank you very much.
