I fully understand that.
I just didn't see where that would occur in the circuit I posted.(555 pin above VCC)
I don't think the circuit will exceed the 555 limit of 70°C (158°F) where it's located at the front of the car (unless it's parked facing the sun on a summer day in Death Valley).![]()
Since the substrate diode is Si, and the substrate diode is also Si, then this is unlikely to "blow" it.Reference schematic of post #8
Assume the automobile battery voltage is 14V.
D2 will produce 13.4V on the 555 VCC
But the 555 trig input is connected to the automobile 14V line.
Thus Trig will be 600mV above VCC which will almost certainly blow the substrate diode, especially when you take any hash on the 14V supply line into account.
Adding a 5K to 50K resistor between the 14V line connection dot and the Trig pin would take care of this...At initial turn on the situation is much worse: VCC= 0V and trig = 14V...
Once again, putting current through a substrate diode, especially the implied current, is not permitted. It is also unwise, and unnecessary.Adding a 5K to 50K resistor between the 14V line connection dot and the Trig pin would take care of this...
Hy AMB_IVI have heard GM's charging system can deliver voltage > normal in certain charging conditions. **broken link removed** says the 2006 SRX has GM's Regulated Voltage Control and that under certain conditions the peak voltage can go as high as 15.5 volts.
Sounds good to me.Hy crtuschow,
I suggest the Infinion (International Reectifier) AUIRF4905 PMOSFET for the circuit of post #11. https://www.mouser.co.uk/ProductDetail/Infineon/AUIRF4905L/?qs=/ha2pyFadugmiTKZf7/IVqC62V4S//duFS%2b0oBuVCUtF9V3Iptmw6w==
It is automotive grade, comes in a TO220 case for easy handling and good power dissipation and has a medium gate drive with a minimum gate threshold of -2v.
spec
Unlike you, I have designed, layed out, fabricated, and tested Integrated Circuits. I can tell you that the substrate diode on a Bipolar process (like the 555) will happily pass a transient of an Amp or so without damage. It is a Silicon diode, so has an IV curve similar to a 1n400X. The ultimate limit on injecting current into/out-of an input pin is fusing the bond wire between the package pin and the chip inside the epoxy.Not true Mike. The diodes are completely different- the substrate diode is very delicate compared to a 1N4148 and 1N4001. Besides, taking the 555 pins outside the supply lines is not specified on the 555 data sheet. In addition any hash on the 14V line will instantly fry the substrate diode.
