The climate changes, always has, always will. We aren't going to change that. CO2 is such a small factor, but such a strong focus, which is why I believe the way I do. The GW team would have better credibility if they could show more of the story, rather than one weak point. Climate changes aren't solely bases on man's CO2 emissions, not even a large enough portion to get all worked up about. Ice core samples? The polar regions are tiny compared to the rest of the world, yet that was where this whole mess started. Why even consider tree growth rings? Because the are similar to the layers in the ice core samples? Guess the GW guys really like boring holes into things, tree-buggery? Trees growth isn't year round, mostly in the spring/early summer, not going to tell you much beyond a few months per year, don't need a PhD to be aware of that.
Climate changes are the combination of a number of factors, and there are limits to how far they swing each way. This whole Eco-trend doesn't address any other reason why temperatures appear to be rising, and don't have much to say about an upper limit or turning point. We are being deliberately lead to a certain predefined conclusion, based on some questionable data, and weak science. We are being sold theory and hypothesis as hard facts. We are being lead to believe that the temperatures will never stop rising, and little or no CO2 is being removed from the atmosphere.
I just don't buy into there is only one cause, and only one conclusion, one solution. There are usually many ways to look at things, several solutions to every problem, why is CO2 the magic cure all? This is just one small step, once it's given governmental power, it's going to keep growing, because we aren't going to see the results.
I learned a long time ago, that people pressuring you into buying something immediately, are usually trying to scam you out of your money...
